Hi all,
i've got few questions, cose i am total noob for oc and stuff... I have following :
4960x
sabertooth x79 (bios 4608)
4x4 quad kingston beast 2400mhz
water cooling : cm nepton 140xl
seasonic 1000w plat
devil13 7990 hd
intel 730 ssd 480gb
thermaltake v71 with 4 fans inside for good flow inside
I've tried to set XMP profile 1 in bios , than xmp profile2, and bios automaticly clock memory to 2.4ghz and turn on turbo clock on processor and clock to 4ghz . And that was not stable, i've got overclocking failed msg 1/3x after bios load up , than i've got some problems during stress test / bsod showed up / couldnt pass test's etc.
Now, i just turned on Performance mode in bios, and look like bios clocked this very well this time, turned on memory to 2.333mhz , and processor on 4.12ghz .
I would like to ask is this temperature good / reliable for stable work :
i really need high speed memory for my work cose i am using it a lot !
i have tested this with intelstress test and it worked for 5minutes and everything was fine/pass test. But temperture was max 80on full load , and on avg. was 65-70 during full load. During my work i am not use full load i am using load on picture above.
It also throtelling from 1.304v to 1.296v, and 4.124mhz to 4123, but i guess thats nothing
Hope to hear from you all soon
Ty
4960x
seasonic 1000w plat
devil13 7990 hd
intel 730 ssd 480gb
Ty
