3XS Chameleon
  • Thread starter Thread starter [E-PCs]
  • Start date Start date
E
[E-PCs]
Guest
Has anyone else seen that new system on Scan's website ?
The 3XS Chameleon
If you look at the options / configure list....
"Chameleon Heat Sensitive Custom Spray Finish & Case Modification (£1,225.00) add £1,225.00"
£1,225 for a paint job
Even just the standard paint option is £650. :eek:
I can't see many people adding that in the options list
Also, if you go through the configuration options, and spec it out to the max it comes out to over 7 grand, for which is really only a basic SLi rig with 20" TFT & speakers.
Seems a tad OTT if you ask me.
Especially if you compare it to a Bespoke system from EP.
The scans rig doesn't even have 7800GTXs.
*Rant Over* ;)
Expensive to start - total ri-off at the end - why bother?
Phil's stuff aint cheap, but seeing things like that makes you appreciate that Phil offers a great cost effective solution at an affordable price.
That's to say it looks like it's worth what you paid.
The Legend
I saw this the other day. I wonder how good their pain job is? After recently buying a anodised case from Phil I can't see how it would come close to it.
Another company offered the same paint as used on the TVR....the shimmering stuff which is a snip at £500 per litre. If I had the money, I would consider that for some BLING for my case. I think. Or I could buy an FX or a Mach...
The difference in finish on a case that phil supplies compared to a case done with the £500 a litre TVR paint is probably minimal. Why would anyone pay £1000+ for an anodised case when you can get one thats just as good from phil for like £300 :S - obviously if you had money to waste but thats not the point.
I spoke to this one bloke (some random on my msn) who does custom pc painting and he charges between £1000-2000 because the finish is that of a ferrari - silly money!
Phil
I think thatys why they were using TVR paint... to try and make it look better. It kinda worked, but not totally.
"You cant polish a turd, but you can stick a flag in it"
That TVR paint stuff is too OTT for a computer IMO, looks like you are trying too hard, Phil's cases look stunning (best paint jobs i have ever seen) but with the smooth finish and single colour, dont look like they are trying to hard to look good, they just do.
G
