maverik-sg1
Just to let you guys know I have been putting my volt modded cards through their paces.
I have come to the conclusion that this benchmark, for me, is CPU limited beaten in orb only by guys that have higher CPU clocks than me.
I think I got me an FX55 WR (or at least a WR at 3511Mhz clock speed) but it would appear that is the limit now of the CPU - I need a cascade system now to kick some butt and get those clocks higher (at least 3.6ghz is required).
Even if you have a set of volt modded 7800GTX's that do 600/1500 it seems that if your cpu wont go higher than it did before, you will no longer benefit in this benchmark
So time to focus on 03 and 05 for now -then some overdue customPC benchies for good measure
The Coach
The Coach
