3750k overclock
pipman2006
I am looking at moderately over clocking my 3570k. I have a corsair H60 and a AsRock z77 extreme 4 motherboard. Does anyone have a profile? Or any suggestions at what i should safely overclock to?
I'd try going to 4.1GHz on stock volts, and see if it's stable or not. For stability, download Intel Burn Test and run the 'maximum' stress level for 10 runs. Also use CPUID HWMonitor, or something equivalent, to check your temps during the stress test.
If it's all stable, you can begin to progress up the MHz-age and voltage.
Fair enough. I may push higher at a later date, after exams and stuff. Just not now when the cpu is 2 days old.
Remember to turn turbo off btw! Otherwise it wont boot at all and you'll go through more and more volts to try and get it to unnecessarily.
i get my 3770k comfortably to 4.55Ghz using:
x44, blck 10350 (103.5) at 1.25v. it holds stable perfectly and heat is more than manageable (highest of 69 during a 24hr 100% FAH session)
so can't see the 3570k (which is basically the same, just a smaller igp) being too much different although the h60 may be a slight issue (unless you whack nf-f12's in push pull lol)
I'm currently trying to down my voltages, and I'm currently running 4.5ghz at 1.185volts. So far passed 2 runs on max of IBT.
Pretty impressed with those so far.
Ivybridge is so easy to overclock until you get to the 4.6/4.7ghz mark at which point you need to put so many more volts through it, and therefore increase the heat massively, which I dont really think is worth it IMO. Far easier just to have the fans on 7v, or even maybe 5v if you can get away with it, and just sacrifice those extra 100/200mhz
Reached the limit, stable at 1.176v!
Not bad
How many IBTs do i need to count the OC as completely stable though?
I'm back up to 1.184 now, at 1.176 bad things happened haha. Ran the 20x test on maximum, and on the 19th I failed :/
