32" Screen advise - whats good?
Biggtony1966
hi, i'm looking to do the same but with all the jargin the companies give you it gets confusing at times. benq BL3200PT is a good 32" on overclockers for £400 but i don't know if it is any good for gaming. can anyone give any ideas for a 32" mointor for gaming please.............
Moved into your own thread dude.
There arent many 32" screens about so youll not get much choice.
You say "not very good for gaming" - what do you want in a gaming screen compared to for arguments sake a normal TV?
hi, thanks for replying, a good tv will work just fine but with tv's the resolution is only 1920x1080p i think. i would prefer going to1440x? but i would settle for the above. i have a 32" toshiba lcd now which is couple of years old now and i have just upgraded my system and i have a asus gtx970oc card and i am experiencing lag on desktop and in some games. what i mean by lag is when you use the scroll wheel to move the page down or up i get a constant flicker/wave across the screen which i never had on my old rig. if i drop the resolution it goes away but larger icons, any advise you can give would be great. i have around £500 for a new tv/monitor, thank you
yes, tv is toshiba lcd 32" i have upto date drivers for my card, don't know why its doing it, thanks again for the quick reply
