Thanks to this tip I found out that my only options are:a fan speed reducer cable would be your best bet mate
1. The one you listed
2. Something like this http://www.silentiumpc.com/en/fanster/
3. A normal 3.5'' bay fan controller.
Thanks for the answer.
^^ ThisYou could also swap the pre-installed fan with a PWM enabled one
Heh. Right. That is actually cheaper and easier. I'll take that route.
Anyone could recommend some cheap PWM fans? Like up to $12.
some motherboards are able to control the speed of a non pwm cpu fan. Worthwile to check your mainboard manual and bios.
you need a cable like this:
http://www.ebay.co.uk/itm/Phobya-Ad...Pin-Socket-Fan-Cable-30cm-Black-/231414525235
and your problem is solved
that wouldnt make a single diference :lol:
