2560x1440 which cards
Heebs
I'm running my games on a 2560x1440 resolution and a single card isn't cutting it.
will I be okay memory wise with 2x 570s?
Should be ok, but if you have doubts there are the 2GB HD69x0 cards. I would go with the 570 SLI setup as a personal preference as I experienced various issues with AMD cards when using a dual-link DVI output at 2560x resolutions.
