Hi, I was just wondering if a 240 radiator and 120 radiator in 1 loop would have the same results as a 360 radiator? Would one be better than the other or would they have the same temperature....?
I know that a 360 radiator would likely be cooler, but if one had a strong pump... Would a 240+120 radiator keep the temperature as low as a single 360 radiator?
They will be about the same. With the two rads you will have the same about of cooling area. You will cause more restriction for water flow, but it will be minimal. It also depends on what you are cooling as well.
