24" Monitor from Pixmania
pazman4
Hi, I’m currently looking for a 24" monitor and would love some second opinions. I want HDMI connectivity and would prefer to buy it specifically from Pixmania as I have a £25 voucher for products over £150. My budget is £200 (excluding the voucher).
My current top choice is this SAMSUNG SyncMaster P2450H 24'' Wide TFT Screen (2 ms)
http://www.pixmania.co.uk/uk/uk/3613396/art/samsung/syncmaster-p2450h-24-wide.html
This does look good but would love some opinions on whether i can get a better deal. Thanks in advance.
LED is just the back light, I have a BenQ led monitor and I notice no difference to normal monitors. The main advantage is the energy saving. About 25w versus 40-50w. ;)
i`v bought this one cLiCk and i can say only the best words :) someone said this monitor have bad menu (touchscreen buttons)
but i can say - its realy easy to use them. i like LED technology as well, go to some local electronic shops and have a look difference between standard LCD and LED LCD, you can see it with an eye easily. Theres one problem - this monitor is over your budget ~240 £
