AlienALX
Well-known member
OK so phase one is complete. Just figured I would do this for any one considering the cheap 2070s doing the rounds right now. Mine was £365.
Test setup is as follows, this is the AIR test not the water test.
X99 Godlike gaming
16gb quad channel DDR4 2666
16 core Haswell Xeon @ 2.4ghz
KFA2 2070 Super OC - clocked to 1965mhz
Asus 2070 Dual Advanced Evo - clocked to 1900mhz (hard lock)
Nothing has changed here apart from the GPU. Both using the new driver.
2070 Super results.
2070 Dual Advanced Evo results.
TBH it was a lot closer than I thought it would be.
Next week I will be testing the 2070 under water VS my Titan XP. Though do note, that will be a in a different rig with a Threadripper. I shall add the results as and when.
X99 Godlike gaming
2070 Super results.
