20 to 24 pin convertor
Arterion
Hey all.
I have a mini-ATX mobo with a 20-pin power connector on it, but the PSU I have has a 24-pin interface. Anyone know if theres an adapter available to connect the two? I bought a cable, but didn't read it properly and ended up with a female 20-pin end with a male 24-pin. Help appreciated!
Your Tagan should have 1 mate, I'm sure I took it off when we swapped out the P4 stuff for the AMD.
Have a check in the box and also make sure its definately not connected to your unit lol.
Boardy
You're right, it did, and its being used- this is a different computer, i'm building one for a friend. All sorted now though, although it's a waste of the aforementioned convertor! Turns out the ATX plug on the mobo had a detachable 4-pin segment at one end to turn it into a 20-pinner. Would be nice if they put that on the instructions though! Lol.
