N Nick R New member Jun 22, 2008 #1 I intend on using two PA120.3's in the same loop, can I/should I use two pumps?
N Nick R New member Jun 22, 2008 #3 Ok, so I'm thinking this: with a QX9775 to as fast as I can get it.
L Luigi New member Jun 22, 2008 #4 QX9770 i hope, the 775 is for skulltrail Thats a lot or rad, A single pump should be fine through that, similar to what im doing, but im using quads Seen as its only a single block, 1 pump is fine Have you looked at phase?
N Nick R New member Jun 22, 2008 #5 So it is, my mistake, couldn't remember which was 775 and which was 771 xD. I've glanced over it but it would prefer to start at a slightly lower step.
L Luigi New member Jun 22, 2008 #6 Ok, Sounds good then single pump will be fine... I was going to call all that radding ott then remembered my builds gna have 2 quads
N Nick R New member Jun 22, 2008 #7 Ok then, the only real reason for two rads was to add some expandability such as graphics card, memory etc.
E EazzyTarget New member Jul 1, 2008 #9 Just wondering what is it you are gaining by hooking the pumps in serial? To increase flow rate through the loop they would have to be in parallel... no? Otherwise, there is no appreciated gain... is there? -EazzyTarget
