2.8 @ 4382Mhz Mach 2 GT cooled
Brwmogazos
Swapped my 3.0C with the 2.8Chip so that i can then select which one to keep.
made a bit of progress with my 2.8 chip and the GT...
temps look way to low though and it was a max screen shot...
Its my front plate which is busted...the screws wont bite at all so i have to leave it as it is...loosing some contact pressure from that and its both two screws on the left side of the baci plate :(
left the agp and pci locked to check max screen
so here it is
wish it was stable at that speed :D
P4C800E
just got another one today
RMAd it :)
need to volt mod it now...
ram wise i am using the 1gb of ocz BH 5 but i have sold those sticks so from tomorrow some adata ddr 500 vitesta
