Hi all,
I finally got all my bits from Custom PCs (prizes) but I decided to add a more powerful GFX, X850XT PE
This card runs so hot that at load you cant even keep your finger on the backplate for a couple of seconds without suffering some serrious pain. ATI tool registers a core temp of 90 c at load. So I got to work...
I added a stack of cooler master heatsinks on the back plate and...
..120 mm fan in the window, thanks Cashman for the info on hole cutters.
The core sits happy at 70 c loaded now and the back plate is just warm. Main system specs;
P4 3.4 @ 4.01 Ghz on air (Asus ice star cooler) prime stable.
1 Gb DDR2 Corsair PC5400 C4PRO
X850XT PE @ stock so far
250 Gb Maxtor Sata
250 Gb Maxtor Sata
