This is mostly just a sounding board of my thoughts, but advice would be welcome...
I'm planning an upgrade of my main gaming PC.
I'll be keeping my 560ti (no point upgrading that yet as it'll be at least £250 for anything more powerful) and PSU (1500w) so it's just the motherboard, CPU and ram I need...
Currently running a Q6600 (running at 3 GHz with a freezer 7 pro) on an Asus P5QC with 8 GB of ddr2
wanting to upgrade to the 1155 family so I've pretty much set on the i5 3570k was i7s are out of my budget and as the other i5s aren't really that much cheaper getting the unlocked one is pretty much a no brainer for me.
Motherboard-
The question now is... which of the vast selection of motherboards should I go for... my budget for the 3 components its £350-400 (could possibly go to £450 but only for a really good reason)
I've looked at the £70-140 Z77 boards offered from Asus, Gigabyte, Msi and Asrock and to be honest they all seem pretty much the same for "unique features" etc. all have 1 pci-e 3 x16 and the other (if there are any) are only running at x8 or x4. Same # of Sata give or take two and so on....
As I am only planning to use one GPU (560ti), I only need the one pci-e 3 x16. One 120 GB SSD system drive (possibly get another and raid 0 it) and one 1.5 HDD for storage so won't need masses of ports. Don't need too many fan connectors as I'll probably be using a controller anyway. They all seem to have Virtu MVP (looks like something at least worth playing with) and UEFI so that won't be swaying me.
I'm mainly looking at the Asus p8z77-v range (inc lx, lk and le) as I've Asus motherboards for the past 10 years of upgrades and they're behaving well (although I am open to another brand)
So the main question is do I spend £75 on the low end (p8z77-v lx) or the £130 (p8z77-v)? or one in between? are the added ports, slots, features etc of the £30-50 more expensive models worth it? or should I not eat for a month or 2 and get the £300 maximus extreme? (Or similar pricier motherboard)
DDR3-
now onto the DDR3 - this also will be a price vs. performance thing - do I go for 8gb 1333mhz for £35ish (as realistically I'll only need 8gb for gaming for the foreseeable future) or do I go for 16gb or 32gb and have fun with virtual ram disks? Is the extra £££ for 1600, 1800, 2133 etc worth it? Should I pay more for CL7 or just stick with CL9-11? And if I get my 8 or 16 in 2 or 4 DIMMs? would there be any real performance difference?
CPU-
as I say earlier the i5 3570k is a no brainer (unless you have good reason to go for another?) and I'm planning on cooling it with the Arctic cooling Freezer i30 (£25-30 320w of cooling goodness) as I've been very happy with the freezer 7 pro rev.2 I'm using on my q6600 and the reviews are mostly good. but again I'm open to suggestions.
Case-
Now I'm thinking of a new case - main wants being extra expansion slots and lots of fan bays so my cooling options are opening right up. I've found 2 cases that are looking pretty good within the -£150 range...
Xigmatek - ELYSIUM
http://www.xigmatek.com/product.php?productid=122
Akasa - Venom Toxic
http://www.akasa.com.tw/update.php?tpl=product/product.detail.tpl&no=181&type=Chassis&type_sub=Full ATX&model=AK-TOX-01BK
Both have 10 expansion slots (hard to get for under £150) and enough fan bays (120mm+) to keep me happy and they even come with a few fans included.
With an "extras" budget of £150-200 I should have enough left to buy any more fans I need, and I might treat myself to a couple of cables and maybe even some light to tart up my case.
Final thing that I really do need advice on is the age old question of ... "onboard vs. soundcard?"
I know this question has been answered 100s of times in 100s of forums for since the first motherboard with onboard as released but as I've only got Logitech 2.1 speakers and some £15 headphones I don't think I need a state of the art studio quality soundcard. The only reason I'd consider getting a new soundcard to go with this new build is if the performance boost was worth the £30-50 min that low end pci-e cards cost.
I do have a Sound Blaster Audigy pci card I bought a about 5 years back, would that offer and performance increase? (assuming the motherboard I go for has a pci slot)
so after all that my build looks something like...
P8Z77-V
i5 3570k
8GB 1600MHz DDR3
GTX 560ti
1500w PSU
Motherboard-
DDR3-
CPU-
Case-
Xigmatek - ELYSIUM
Akasa - Venom Toxic
P8Z77-V
i5 3570k
8GB 1600MHz DDR3
GTX 560ti
1500w PSU
