WYP
News Guru
Higher TDPs mean higher PSU requirements.
Read more about RTX 3090 Ti OC models recommending 1,000W PSUs.
Yeah as soon as I saw the Kingpin using two of those dumb Intel connectors I figured stuff was going to get stupid.
Ahh, technology. Dragging us 9 years backward.
To be fair these cards are not meant for the 99.99% of users, They are meant for people looking to break world records on LN2 that need unrestricted power, For the majority, Stock and supply issues aside, Exists the 3060/70/80 which are all very efficient especially when you compare the performance plus total wattage to the last gen, Quite nice gains.
The Intel connector is also pretty smart, Linus did a video about the implementation around a year or so ago and the power savings it can give, If the PSU and motherboard have this standard too, Are actually fairly impressive.
Actually no. For every single GPU generation you could hear "Nvidia locked the power of this cards." 3080 and lower cards exist and they are plenty for most people, and they have reasonable power consumption.
Flagships should always be balls to the wall, unlocked, unconstrained. It is good that we are getting full power of the latest flagship silicon.
Nothing has improved since they "unlocked the power". Nothing. At all. You could still easily overclock a 1080ti to 2ghz and more on water. Power was not preventing anything at all, apart from RMA. That is why they did that, not to stop you overclocking or having fun. In fact, from the moment they locked the power on cards? that was when the automatic overclocks started. AKA "Boost frequency" because that is basically what it is, automatic overclocking. You could push further, and you could easily reach a safe limit where your card would not go any faster and crash - because of power and heat. Nothing more. It was literally done to stop people cooking their cards and returning them.
I can unlock the voltage on my 2080Ti very easily. The problem is firstly it will void my warranty, but secondly there is absolutely no point AT ALL. My card tops out around 2180mhz on water, and that is all it has to give. Unlocking the voltage would not do anything unless I wanted to put it under LN2, which is totally impractical. I want to game, not set benchmark records.
The reason they have "unlocked the power" on Ampere is because they had no choice. Like I said to Dice, as impressive as you may feel it is the power it uses is an absolute insult. However, it is also the reason they unlocked the power. Otherwise it would, in order to meet sensible power use levels, be slow and crap. Because it's a crap node.
I tell you what. Debate with me all you like. Fair play. However. You wait until they go back to TSMC. All of a sudden they will be bragging about how efficient their cards are.
I agree that Samsung's node is a bit of a dud for this generation. But that was not my point. It doesn't matter if it is only 5% performance gain for 50% of extra power flagship class cards should let you do that. The whole die, all the memory, and all the power. Like with ROG Extreme boards. Barely anyone buys them, they give you no extra performance for a lot of extra money, but they exist and they have everything and more for someone who wants them. That is what flagship should be.
Intel will be Intel they are going to spend big bit like MS with Xbox.
They will get worse I feel power wise the newer GPU's coming are going to dwarf my 6800XT it'll go to mid range power, nvidia will be better the 2nd next gen coming as atm they plan to go one big die until they go chiplet they will suck power.
I can very much see 500Watt + maybe at the top end 600watt in next gen, thou at least they will be powerful cards as for the prices get ready for a heart attack as i feel they will keep producing the current gen at the same time either they will fill the midrange and lower end products or keep it as 2 series wouldn't be the first rebrand in our history.
The issue that I find with this is that it sets a bad precedent regarding efficiency. Once they set a foothold in the top end about a terribly inefficient product, it will trickle down and then all of a sudden, we're back to using multiple power connectors on midrange hardware again whereas in when this day and age, they should top out at one external power connection and no more than that.
To me, a flagship should be the product that showcases everything that line has to offer, efficiency being included. It's no good having the flagship scream performance while guzzling a ridiculous amount of power to do so because all that does is showcase how that product line scales terribly.
To me, this situation is a lot like cars. If you want to mod your engine for more performance while throwing fuel efficiency down the toilet, go ahead, you're free to make that choice. But the manufacturer shouldn't have that as the default, it should be properly tuned to meet the best performance/efficiency balance possible then the users can decide beyond that. Having it readily available just creates a mess that I've explained in my first paragraph
This, why use should all computing continue to increase its power consumption to this extent, why not all drive 6.0l v8's everywhere all the time and never walk again.
We don't all drive Ferrari's everywhere because we don't need to, but right now there are not enough lower and mid range items available and those that you can get are being sold the price of Ferrari's.
