Go Back   OC3D Forums > [OC3D] Hardware & Software > Networks & Security
  #1
Old 08-03-21, 03:48 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Real Time Network Monitoring ?
Just curious if anyone knows if it's possible to monitor the real time upload/download of a network using software, My ISP is EE but the actual router doesn't have this function built in, Could I monitor the IP of devices connected to the network through some 3rd party program ?
I had a look around google but all I got was some dodgy looking links to software I've never heard of that want hundreds of £££.
__________________
= Steam/Origin/Uplay - Dicehunter =
  #2
Old 08-03-21, 08:11 PM
AMD Enthusiast
Not sure if you are allowed to but you could always try flashing the router for dd-wrt, tomato, or openWrt as they are free. Have to check compatibility list I believe.
Otherwise the only free tools(even paid I think) will let you monitor just your device. I don't think you can monitor all router traffic/bandwidth from your PC. You'd probably have to have something like a dedicated network OS that's handling everything with the router such as pfsense.
Could be wrong I never delved into Networking as much as other areas of IT...
  #3
Old 08-03-21, 08:46 PM
hmmblah's Avatar
hmmblah hmmblah is offline
Moderator
Does the router belong to EE or to you? Easiest thing to do would be to get a router that supports this. Ubiquiti is a great choice and will give all sorts of stats on the connection with very little set up or playing around with things. Mikrotik does this too. Most home routers I've dealt with in the $150+ range have some kind of built-in stats. I mostly stick to ASUS and Ubiquiti now.
If you can log into your current router that doesn't support this, does it support sending logs to a syslog server?
__________________
CaseLabs Mercury S3 | AMD 3900X | ROG CH8 Impact | RTX 2080 Super | 32GB DDR4 | 1TB NVMe
Acer Predator Z35P
  #4
Old 08-03-21, 09:08 PM
grec grec is offline
OC3D Elite
There's an app called Fing that shows you all the devices connected to your WiFi network and their IP addresses if you just need that aspect (And has a list of state changes, IE connect/disconnect/ect)
  #5
Old 09-03-21, 01:28 AM
looz's Avatar
looz looz is offline
OC3D Elite
I'd configure your router to function in bridge mode, and buy an ubiquiti edgerouter for your network. Though that also requires a separate access point for wifi.
__________________
i7 9900k - 16GB - 3080 XC3 Ultra - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
  #6
Old 09-03-21, 01:56 AM
AMD Enthusiast
Ya most newer routers I have seen have some sort of UI interface for built in stats/configuration. I use Asus personally. Has the benefit of Merlin firmware support which is pretty neat.
As suggested though Dice a few options but they will require money. But you love to buy new things LOL
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
