Go Back   OC3D Forums > [OC3D] Graphics & Displays > Overclocking
  #1
Old 11-11-20, 06:30 PM
john007 john007 is offline
Newbie
10900k + z490-e rog strix Over problem!
I dont put stable at 5.1GHZ all core, with less than 1.33 llc6...
With cinebench r20 with 91c n some cores.
With a 850w xfx gold modular
1 stick of generic ram ( 8gb )
lian li galahad 360 AIO
( without gpu, dont have come yet )
Can i let this way? or is so much Vcore?
With settings i have do put in bios? do make better overclock?
Can i put Vcore manual to UV the cpu, but still taking intel performance? (5.3 on 2 core )?
Thanks!
  #2
Old 01-03-21, 09:20 AM
Etihad Etihad is offline
Newbie
your temps are more important than vcore. As long as your temps are fine it doesn't really matter with regards to voltage. Heat is the cpu killer not voltage.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
