Go Back   OC3D Forums > [OC3D] Hardware & Software > Storage Mediums
  #1
Old 16-06-20, 01:59 AM
Kleptobot's Avatar
Kleptobot Kleptobot is offline
Advanced Member
NVME Boot on Z77
Hi All, not sure if people will care as this is fairly old news and has been covered before.
But thought i would chronicle my experience here so other people with similar hardware can know it works.
I recently modded the BIOS of an asus maximus gene V to support booting from pcie NVME drives. The base version i modded was 1903 which is the latest available from asus for that board.
I did not pioneer this and just used already available information, but i can confirm it works.
The board does not come with any m.2 ports so i had to use an adapter card. And to get it to work i had to disable CSM in the BIOS.
The adapter card was a SilverStone ECM25
And the drive was an ADATA XPG SX8200 Pro 1TB
This is now the only drive installed in the system with no other workarounds needed.
EDIT: I just realised i posted this in the wrong section, can it please be moved
__________________
delided 3570k (watercooled)
hd7970 (watercooled)
8GB Gskill XM
3*140 SR1 Rad
all stuffed in an FD arc midi
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
