Go Back   OC3D Forums > [OC3D] Forum Teams > Redline Folding @ OC3D - 98860
  #1
Old 02-04-20, 01:11 PM
chrisjones chrisjones is offline
Newbie
Send a message via MSN to chrisjones
Anyone know if COVID-19 is being processed on the GPU or the CPU?
Does anyone know if COVID-19 is being processed on the GPU or the CPU?
My rig is running GPU only right now, but the 2080 Super seems to get on pretty well.. generally averaging ∼105,000 points per WU and chomps through them in around an hour and a half if anyone was curious.
It does seem to have an issue being assigned Work Units, but I'm not sure if that's universal right now with how many people are folding now!
Just wondering if I need to put CPU back on (at idle) as I use the computer day to day and will occasionally disable the GPU so I can play a game or two.
__________________
Fractal Define R6, Asus WS390-Pro, Intel i7 9700k @5.2GHz, Corsair Dominator Platinum 32GB @3200MHz, EVGA RTX 2080 Super, Corsair RM1000i, Noctua NH-U12S, 2x Samsung 970 Evo M.2 1TB SSD, 1x Sandisk Ultra II 960GB SSD
Fractal Node 304, Asus Z87I-Pro, Intel i5 4670K @4.2GHz, Corsair LP 8GB RAM, Gainward GTX960, Corsair RM550, Corsair H75, Sandisk Ultra II 240GB SSD, 1x WD RED 3TB, 4x WD Green 2TB
  #2
Old 02-04-20, 01:17 PM
Avet's Avatar
Avet Avet is offline
OC3D Elite
https://www.overclock3d.net/news/sof...ght_covid-19/1
There are some WUs that are designed for CPU-based folding. And yes WUs are a bit scarce atm so it is completely normal not to have anything assigned.
__________________
Turbos on an engine is God's way of telling you it ain't got enough cylinders.
  #3
Old 03-04-20, 10:50 AM
Newbie
Thanks for the quick reply Avet! Great article there, exactly what I needed.
I've enabled the CPU again, guess I'll just have to use the laptop as the daily for the moment!
__________________
  #4
Old 05-04-20, 02:13 AM
stevehat1 stevehat1 is offline
98860 #1 Folder
I enabled CPU folding in conjunction with GPU folding. I had forgotten how much more efficient GPU folding was. The total PPD with both enabled was less than just the GPU my itself. The heat output was noticeably higher with both enabled and fewer points which relate to the amount of science contributed. This made it a lose lose situation with fewer points/science contributed and more electricity consumed
For the time being I'm going to let the close to 600,000 currently contributing CPUs carry on the CPU effort and I'll stick with GPU folding.
__________________
Folding since 1 WU=1 point.
Proud to represent OC3D on the 1st page of all Folding @ Home donors
  #5
Old 05-04-20, 04:47 PM
hmmblah's Avatar
hmmblah hmmblah is offline
Moderator
steve, when you enabled CPU folding did you allow it to use all cores? I allowed it to use all cores but 2 so there would still be a couple cores for the GPU client.
__________________
CaseLabs Mercury S3 | AMD 3900X | ROG CH8 Impact | RTX 2080 Super | 32GB DDR4 | 1TB NVMe
Acer Predator Z35P
  #6
Old 05-04-20, 11:10 PM
98860 #1 Folder
Tried it both ways, default and then 10 cores CPU with 2 cores GPU. It didn't seem to make much difference which way I tried. Total PPD was less noticeably less with CPU folding enabled.
So nothing appears to have changed, it was the same thing a few years ago.
__________________
  #7
Old 06-04-20, 07:49 AM
trawetSluaP's Avatar
trawetSluaP trawetSluaP is offline
OC3D Crew
Considering my CPU uses more power than my GPU and offers maybe 10% of the same efficiency for Folding I decided to give it a miss.
Anyone else noticing their points are being given in chunks and not at the right time?
__________________
5000D | R7-5800X | X570 Tomahawk | Dominator Platinum 32GB | RTX 2080 FE | 960 Pro 512GB | EVGA SuperNOVA 1200 P2 | ViewSonic XG270QG| Custom Watercooling Loop + Aquaero 6 XT
  #8
Old 10-04-20, 11:37 AM
Newbie
Yeah I've noticed it take almost 12 hours to update sometimes for me
I'm still running GPU only for the moment, tried adding the CPU back into the mix but the 9700K kicked out a lot of heat so that's a no go with this outside temperature in the UK at the moment, added with my room being south facing..
__________________
Tags
covid19, [email protected]
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
