Go Back   OC3D Forums > [OC3D] Hardware & Software > Cases & Power
Thread Tools Display Modes
  #1
Old 13-02-20, 07:00 PM
CRITICALThinker's Avatar
CRITICALThinker CRITICALThinker is offline
Newbie
RX 470 with 400W Power man PSU.
So I have a build I'm throwing together for a friend with a lightly overcooked fx 6300 and an rx 470, and I can either use a Power man IP-S400DQ3-2 or pull an Antec EA-500 off my ddr2 testbench. While I know the Antec would have no issues, I'd like to get a second opinion on the Powerman since its just sitting here. It has 2 12v rails with limits of 18 and 16 amps between them, and if they bothered to get it 80 plus white labelled it should be able to handle it, but I'd hate to be the guy who didn't check and wind up with blue smoke.
I have been testing it for a couple hours and haven't seen any issues like when I was overclocking a q6600 on a 350w psu that ended up hoping out. Usually I'd make the decision myself on these matters with the experience I have, and if it was a modern single rail unit it would be fine. Haven't managed to get a definitive answer yet, most people point to PSU calculators that provide mixed results.
Thanks all for your opinions.
__________________
|- Ryzen 5 3600 -||- Deepcool Gamaxx 400 -||- Gigabyte X570 Aorus Elite -||- 16GB G.Skill Ripjaws V 3200MHz -||- EVGA GQ650 -||- MSI GTX 1060 Gaming X 6GB -||- Zalman Z9 Plus -||- Adata SU800 1TB -||- 2TB Mechanical Storage -|
  #2
Old 14-02-20, 12:04 AM
Newbie
Aight, ive decided to go with the antec for peace of mind, the power man will go to my ddr2 testbench since it isn't used all too often anyway.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
