Thread Tools Display Modes
  #1
Old 10-01-20, 10:26 AM
g0ggles1994's Avatar
g0ggles1994 g0ggles1994 is offline
OC3D Elite
Best Budget Gaming Keypad
( As the title says, I'm after the best budget gaming keypad so I can get into more Elite Dangerous.
I've been considering something that has a thumbstick so I can hopefully control in game menus with it or the view but that narrows me down to Razer Tartarus V2 or Orbweaver
Has anyone got any experience with these or got any better suggestions? I have considered getting a Logitech G13 but unused ones are like gold dust and I'm 50/50 on second hand models since I don't know how much life they have left.
Normally I wouldn't touch Razer with a barge pole but I feel like I'm backed into a corner on this one
Edit: Forgot to mention I've got a HOTAS (Thrustmaster T-Flight HOTAS X) which a keypad would go alongside because reaching my keyboard is a pain in the neck.
I've considered a new HOTAS but that's way above budget right now
__________________
Ryzen 1700X @ 3.6GHz | MSI X370 Gaming Pro Carbon | Corsair H100i v2 | 16GiB Corsair Vengeance LED Blue
ASUS RoG Strix Vega64 8GiB | 240GB Corsair Neutron GTX | 1TB HGST | Corsair RM850 CableMod | Phanteks Enthoo Pro M TG
  #2
Old 10-01-20, 10:58 AM
Warchild Warchild is offline
OC3D Elite
Hmm little curious. Not sure it would be as immersive as a HOTAS which I believe can be around the same price for some. I didnt find keypads as useful as a normal KB.
Elite Dangerous without a HOTAS requires quite alot of keybinds and I think the thumbstick might need to be used for thrusters if anything.
  #3
Old 10-01-20, 11:17 AM
OC3D Elite
Should have mentioned I've already got a HOTAS sorry but it doesn't have enough buttons for all the Elite commands, keypad is to supplement it rather than replace it.
Problem I've got with my setup is that I've only got one surface for the HOTAS and my keyboard sits behind it and trying to reach around to get any keys can be a nightmare
__________________
  #4
Old 10-01-20, 11:22 AM
OC3D Elite
Funny you say that. I just built a hotas desk mount and was going to add it on here as a build log. VERY simple solution which resolved the problem you have. I had exactly the same! and I refuse to pay 160 euro each for throttle and stick mount.
  #5
Old 10-01-20, 11:23 AM
OC3D Elite
Welp, in that case mate, would you be so kind to share your knowledge?
__________________
  #6
Old 10-01-20, 12:18 PM
Tolemac's Avatar
Tolemac Tolemac is offline
OC3D Elite
Another cheaper option is to use voice attack with one of HCS voice packs I play in VR now with a HOTAS and it's a great tool to have
__________________
Build Log: http://forum.overclock3d.net/showthread.php?t=72241
“If you knew the magnificence of the three, six and nine, you would have a key to the universe.” – Nikola Tesla
  #7
Old 10-01-20, 12:45 PM
OC3D Elite
That helps, but not when searching star systems which is why I thought a keypad also doesnt solve the problem as much.
  #8
Old 10-01-20, 12:49 PM
Tolemac's Avatar
OC3D Elite
yeah frontier really need to sort out the galaxy map in VR
__________________
  #9
Old 10-01-20, 02:17 PM
KingNosser KingNosser is offline
Member
https://voiceattack.com/ seen a few streamers use this in the past for different things something you might use in elite for landing gear and such things good little app.
  #10
Old 10-01-20, 03:29 PM
OC3D Elite
yeah I use it for everthing except star systems. You can even use it to request docking.
HCS Voicepacks are well worth having. Or at least 1 of them.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
