Go Back   OC3D Forums > [OC3D] Customer Care Forums > MSI UK Forum
Thread Tools Display Modes
  #1
Old 16-11-19, 06:15 AM
FTLN FTLN is offline
OC3D Elite
Msi x299 meg creation
Hi MSI,
I have the X299 MEG CREATION with 7980xe and love it but there is one bug which is present in each of your bios releases (tested them all).
When VROC is enabled on PCIe 3.0 slot and the Thunderbolt add-in card is enabled the system does not reboot or shutdown from OS, tested with windows 10 latest releases and Ubuntu server / desktop and both have the same issue. The OS seems to shutdown ok, but the motherboard does not do the final step and reboot/shutdown it kind of freezes and I have to physically press the reset button on the case.
I have also tried multiple bios configs (fastboot disable, msi fastboot disabled, fastboot enabled) and this changes nothing.
If you are still present on this forum , please take note and please fix
__________________
https://valid.x86.fr/6w9bi0
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
