Go Back   OC3D Forums > [OC3D] Customer Care Forums > Asus UK Customer Care Forums
  #1
Old 28-08-19, 03:37 PM
b33rd0g b33rd0g is offline
Newbie
STRIX X470-I GAMING not supporting 3800x? (now 2700x wont work either)
for the record ive built maybe 12 computers and replaced cpu almost as many times, im confident i havent done anything wrong
so i got my 3800x and installed it on my STRIX X470-I GAMING (bios 2703)
and it simply wont boot. the top right LED on the mobo is red. manual indicates cpu error. took out the cpu and put it in again. same result. and again. same result.
the only conclusion i could think of was that the 3800x wasnt supported yet, after all it was available quite a lot more recently than the other 2.
so i plugged in the 2700x. it wont boot either. this time the top right led is orange. orange isnt mentioned in the manual as far as i can see. took it out and in again, same result. decided to do the cmos clearing with the screwdriver shortcutting those 2 pins, as described in the manual. same result.
now im kind of stuck here. any idea what to do?
typing this from a crappy old laptop
thanks
PS the official asus forums are a nightmare to sign up for
  #2
Old 28-08-19, 04:26 PM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
You need to update the BIOS to newer version to support Ryzen 3rd gen. You need to do this with an older Ryzen CPU. If it doesn’t work, then maybe either the CPU(s) are/have gone bad or the mobo. Look up what the error light indicates.
  #3
Old 28-08-19, 04:31 PM
Newbie
its already the latest bios, 2703, its supported ryzen 3 since 23xx something. as i said it wont boot the older ryzen either. wont even go to POST
i cant find anything about thte orange LED
  #4
Old 28-08-19, 05:44 PM
Dawelio's Avatar
OC3D Elite
Now someone with more knowledge, please correct me if I’m wrong here, since I’ve never encountered this myself... But if it doesn’t even go to POST and none of the CPUs now work, can’t the motherboard be bricked?
  #5
Old 28-08-19, 05:45 PM
AMD Enthusiast
Can you roll back to a BIOS you know works?
  #6
Old 28-08-19, 05:54 PM
Newbie
i dont get as far as seeing if the bios even works. when i power on the monitor wakes up then quickly shuts down saying somrthing like 'no signal received blah blah' (yes its plugged in correctly)
it doesent receive any data at all it seems, just the initial power on signal
  #7
Old 28-08-19, 05:56 PM
Newbie
im worried ur right. i just dont know how thats possible. ive done this many times before and i even wore disposable glowes to be on the safe side
  #8
Old 28-08-19, 06:01 PM
Newbie
anyone know where the battery is on this thing?
  #9
Old 28-08-19, 06:13 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
You did plug the cpu power back into the top?
__________________
ASUS ROG Crosshair VII wifi | Ryzen 5 3600 | Custom Loop | Patriot Viper Steel 4133 @ 3600 2 x 8Gb | Asus Strix RX 470 | Samsung 500gb nvme | Samsung 1Tb nvme | Samsung Evo 120gb ssd | Seagate Barracuda 1tb storage | Toshiba 1Tb HDD | EVGA 500w | Phanteks Entho Pro Tempered Glass | Windows 10 and Linux Manjaro
  #10
Old 28-08-19, 06:14 PM
Newbie
yes i did
Tags
2700x, 3800x, x470
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
