Go Back   OC3D Forums > [OC3D] Graphics & Displays > Drivers & BIOS
Thread Tools Display Modes
  #1
Old 07-06-19, 06:16 PM
p1987 p1987 is offline
Member
Aorus Engine and 2080
Hi,
I have tried numerous times to install Aorus Engine software 1.65 with Windows 10. It loads but then crashes out my PC.
It loads up in the task bar and does nothing.
I have uninstalled Geforce Experience, my OC utility, restarted ect.
Any help would be appreciated
Many thanks,
__________________
Ryzen 7 2700x 4.1ghz boost - Gigabyte X470 Ultra gaming Gigabyte 2080 Aorus (1940 -14900) - XFX 750w True Power PSU - 16GB Corsair 'RGB' Vengance RAM 3200mhz
  #2
Old 07-06-19, 11:14 PM
FTLN FTLN is offline
OC3D Elite
I had same issue on my Auros 2080ti, I fixed it by getting downloading an older version. Uninstalled after about ten minutes of using though, its complete garbage compared to Afterburner....
__________________
https://valid.x86.fr/6w9bi0
  #3
Old 08-06-19, 01:51 PM
Member
Hi,
Thanks for the response
Where did you get the older version from ??
__________________
  #4
Old 08-06-19, 02:45 PM
OC3D Elite
Originally Posted by p1987 View Post
Hi,
Some random site found via Google. Not sure which though, most probably the auros forum...
  #5
Old 08-06-19, 02:57 PM
Member
Hi,
If you still have the installer, could you emailed it to me?
Thanks
__________________
  #6
Old 08-06-19, 05:24 PM
OC3D Elite
https://www.reddit.com/r/gigabytegam...nt_even_start/
__________________
  #7
Old 08-06-19, 11:19 PM
Member
Thanks for that!
I will give this a go tomorrow
__________________
  #8
Old 08-06-19, 11:37 PM
OC3D Elite
Thanks for that!
Trust me, its not worth the time and effort, the software is complete pants ! !
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
