Go Back   OC3D Forums > [OC3D] Customer Care Forums > NZXT Forum
  #1
Old 28-01-19, 11:39 AM
OneTwoMark OneTwoMark is offline
Newbie
Help - My two fans plugged into my X52 are running at full speed
I just built my first PC and when I turned it on it was super loud. I have a NZXT Kraken X52 with the radiator mounted to the front of a 460x RGB case. I’ve used the cases inbuilt fans to cool it. Only the top two cover the radiator so I plugged them into the cooler power cables that came with it, but I plugged the bottom fan into the motherboard like normal and that one spins slower. Why would my cooler be making my fans spin at max?
Heres a video for noise sample. (Turn volume up )https://youtu.be/E-Mtvyn8zJA
  #2
Old 28-01-19, 11:57 AM
tinytomlogan's Avatar
The Guvnor
Have you used cam to set the fans up?
Also some of the CPU headers at the top can be an AIO header and these will be set to default to run at 100%
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #3
Old 28-01-19, 12:34 PM
Newbie
I haven’t booted properly yet as my display didn’t appear, but I wanted to focus on the fans before I fixed that because they really bothered me.
Someone told me it was because the x52 only supports 4 pin and my case fans are 3 pin, so I’m going to try plugging the fans connected to the cooler into the motherboard instead. As for the water pump I have that plugged into CPU FAN1
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
