Go Back   OC3D Forums > [OC3D] Customer Care Forums > Asus UK Customer Care Forums
  #1
Old 11-12-18, 02:56 PM
ninezerofive ninezerofive is offline
Newbie
Maximus XI Gene + ROG THOR = Connect RGB?
Greetings guys,
Maybe somebody here can help me. Was very happy to pick up both Thor and Gene units. But as it turns out I can't connect them straight away. The gene board only comes with 2x12v RGB inputs and there only 5v addressable cable and another cable on the PSU. I thought the new node connector cable will be included, but it's not.
Does someone has an idea how can I make this work and use the Aura Sync to sync all together, maybe some hub or splitter or I don't know.
  #2
Old 12-12-18, 04:13 PM
tinytomlogan's Avatar
The Guvnor
You need an addressable header. Does your board not have it?
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #3
Old 12-12-18, 05:00 PM
Newbie
Nah bro, Maximus XI Gene doesn't have addressable header.
  #4
Old 01-04-19, 09:40 AM
AlexB AlexB is offline
Newbie
I had the same problem as you and the only option I could fined was the Asus Aura Terminal
https://www.amazon.co.uk/ASUS-Aura-T...50443738&psc=1
Hope that helps.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
