Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
Thread Tools Display Modes
  #1
Old 21-05-18, 11:49 AM
WYP's Avatar
WYP WYP is offline
News Guru
Sony is working on LLVM compiler improvements for AMD's Zen Architecture
Sony is working on LLVM compiler improvements for AMD's Zen Architecture. Another sign that Sony's next console will use Zen CPU cores.
Read more about Sony's LLVM compiler improvements for AMD's Zen CPU architecture.
__________________
_______________________________
Twitter - @WYP_PC
  #2
Old 21-05-18, 01:36 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
About time they moved away from the garbage jaguar cores.
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #3
Old 21-05-18, 05:54 PM
AMD Enthusiast
Depending on when they want to release next gen I could definitely see them using a custom Zen 2 design. If all they did was use a 4 core zen and kept the GPU holy moly that power increase alone would be insane.
But they better update that GPU. Nothing less than 580 performance and in the next couple years that would be pretty low.
__________________
I am Iron Man.
  #4
Old 21-05-18, 05:55 PM
Dicehunter's Avatar
Resident Newb
Originally Posted by NeverBackDown View Post
Depending on when they want to release next gen I could definitely see them using a custom Zen 2 design. If all they did was use a 4 core zen holy moly that power increase alone would be insane.
I can't see them using 4 cores, 8 probably is on the menu but obviously lower clocks etc...
__________________
  #5
Old 21-05-18, 05:59 PM
AMD Enthusiast
Could definitely use 4 with hyperthreading. Would be enough.
Depends on what they want. They want a stronger CPU or a stronger GPU. If it's the former than a 8 core. If it's the latter than a 4 core but make the GPU stronger.
__________________
I am Iron Man.
  #6
Old 21-05-18, 06:10 PM
Dicehunter's Avatar
Resident Newb
I can see them going with an 8 core mainly to use it as a selling point for the mass market, Like they did with the PS4 at one of the announcements -
"Where else can you get a machine with 8 cores" etc etc...
__________________
  #7
Old 21-05-18, 07:24 PM
AMD Enthusiast
That was in context of consoles though. Because AMD have had 8 cores for a few years by that time.
Heck I wouldn't put it past them to do 6 cores 12 threads.
It'll be interesting. Sony know half the reason they are way ahead of Xbox is because at launch it's specs were quite superior and they had a better consumer oriented approach WHILE being cheaper(other half being far more/better exclusive titles). This next time they need to hit every box again. So it'll be interesting to see how much they want to charge with the given power output while still trying to beat MS. And seeing as MS went all out with XboxOneX Sony definitely should be concerned because MS has far more money to bleed than they do.
__________________
I am Iron Man.
  #8
Old 21-05-18, 09:35 PM
WYP's Avatar
WYP WYP is offline
News Guru
Backwards compatibility with PS4/Xbox One will be important for next-gen, especially for the next Xbox console. I don't see them using less than 8 cores.
While they can get away with weaker CPU cores, developers want more CPU horsepower for next gen. The next-gen consoles will likely use Zen cores at mid-level static clock speeds to ensure stable performance at reasonably low levels of power consumption.
What is killing Xbox right now is exclusive titles, though I agree that in the early days the PS4's extra power and cheaper price were vital to their early success.
__________________
Twitter - @WYP_PC
  #9
Old 21-05-18, 11:09 PM
AMD Enthusiast
Backwards compatibly moving forward is entirely going to be done with emulation. There's just no way to do outside of that unless they stick with the Jaguar cores. And seeing as how they sucked since day one it would be the dumbest move to keep it.
So I say get the power you want and then work on emulation. Put the money towards that. I mean most big titles will be remastered anyway so it will give them time
__________________
I am Iron Man.
  #10
Old 22-05-18, 12:15 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
lmao or a 6.5 core.
__________________
"Those really high 20 series prices are just place holders"
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
