Thread Tools Display Modes
  #21
Old 02-02-17, 10:59 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Have a nice holies bud
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=16gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=Asus ROG Swift=Corsair K95 RGB=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #22
Old 02-02-17, 12:01 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
Less slacking and more pics please
__________________
ASUS Prime x370 Pro | Ryzen 5 1600 | Antec 240 AIO | Corsair Vengance RGB 3000 2 x 8Gb | Asus Strix RX 470 | Samsung Evo 120gb ssd | Seagate Baracuda 1tb storage | EVGA 500w | Phanteks Entho ProM Acrylic Window | Windows 10 and Linux Manjaro
  #23
Old 02-02-17, 12:02 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Originally Posted by Wraith View Post
Trust, I've not been sitting on my laurels this is a real PITA
Water cooling is just that. A severe PITA and an expensive one if you have to buy the parts. With my loops I have wondered how they even work by the time I was finished.
But it's worth the aggro man
__________________
He used to do surgery
For girls in the eighties
But gravity always wins
  #24
Old 06-02-17, 05:06 AM
BBG280 BBG280 is offline
Member
That's what I like to see! It's an addiction that's tough to cure.
  #25
Old 14-02-17, 02:13 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Sorry guys it's been a manic few weeks and possibly a few weeks worthy of the FML thread, but I'll not bore you all with my life and stresses
On to the main event, so after a little wait (always check when ordering from ebay where the item location "Acually" is) everything arrived and I began to plan and piece together the build, going from TTLs original loop order which is what was decided I stick with we did stumble onto a slight issue.
The roof radiator was originally supposed to have a barb come 90 degree down and towards the back side panel then up 90 followed by a 90 towards the front carrying the hose along the back side (hidden) to the front radiator... slight problem as the Sabranco has thermal armour and it just didn't pan out that way, after much juggling various angles around it was found that the barbs worked better out to the rear of the case and back up round the side. So same place different angle, this was the most difficult part of this build and took more time than care to admit.
Now with the radiators in place I could make a start on taking the GTX1070 apart and fitting the Alphacool Eiswolf (GPX-N 1080/70 Pro M01) cooler, having never taken a reference or founders edition apart I figured "meh it can't be that difficult", WRONG! sooooo many screws and parts it was a nightmare. Thankfully the Eiswolf only has 10 simple bolts, a few thermal pads and it's done.
So with that little job sorted and nailed down I threw the GPU and CPU cooler into the build and began hosing which is a blister inducing nightmare also, forcing the hose onto the barbs is bloody hard work let me tell you and FYI they ain't coming off that's for sure.. I digress.
After all that squeezing and shoving I left it at that and went to bed pleased with my efforts. The following day came the bit I was dreading actually pouring fluid into my beloved Rig which was a very slow process featuring chasing large bubbles and lots of rig tipping which after about half an hour your arms feel like they are about to fall off, once enough fluid was in I then began the tedious tipping side to side technique to move the smaller collected bubbles to the drain/fill port at the top. Once I had all I could see out after an hour of filling and bleeding I then left the pumps running for a further 4 hours to check for initial leaks.
Day 3 of the loop build went like so, attached all the the pumps to their assigned headers, connected the fans, enter bios, do some tweeking and that was that.. bish bash bosh. I've been running comfortably now for a whole day and no leaks at all and my load temps are fantastic.
At stock running Valley I achieved a whopping 38c!!!! Overclocks will be coming soon.
And now for the semi finished article I just need to get some accent colour in and pick some new fans of which I'm leaning towards Corsair MLs in White.
So in conclusion is watercooling worth it and addictive, yes and no, I can clearly see the advantage of custom liquid cooling and while stressful at times it is fun to do and something I think every enthusiast should at least try, as for addictive I can't personnaly say it is I'm not rushing to OCUK or WCUK just yet, but I might do in the future just to tart things up a bit and maybe look at rotary fittings. All in all I've had a blast and thoroughly enjoyed doing this and again Thank TTL, Fractal and Alphacool for making this possible and finally getting my feet (rig) wet.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #26
Old 14-02-17, 02:19 PM
Tolemac's Avatar
Tolemac Tolemac is offline
OC3D Elite
IT LIVES . nice to see it up and running and at least you have another string to your bow Wraith
__________________
Build Log: http://forum.overclock3d.net/showthread.php?t=72241
“If you knew the magnificence of the three, six and nine, you would have a key to the universe.” – Nikola Tesla
  #27
Old 14-02-17, 02:24 PM
AlienALX's Avatar
OC3D Elite
Awesome and very clean indeed !
__________________
  #28
Old 14-02-17, 02:25 PM
Wraith's Avatar
Bettyswollocks
She sure does, a few micro bubbles but they are working there way out.
__________________
  #29
Old 14-02-17, 02:37 PM
tolagarf's Avatar
tolagarf tolagarf is offline
OC3D Crew
Sweet build! Personally I would have used clamps on those hoses, but I guess it's a personal choice (at least make sure your home insurance covers electrical and water damage!).
I'm impressed that you got the GTX 1070 down to 38C, I guess the 1080 runs a bit hotter. Mine ran 45-50C when I had the same cooler attached. Actually I just ordered a new one to hook it up with my Eisbaer, as the former one had a defect.
  #30
Old 14-02-17, 02:57 PM
Wraith's Avatar
Bettyswollocks
I'm not even joking when I say this but those hoses are so damn tight, while fitting one which I'd cut wrong I had to cut it off with a stanley knife it simply would not let go of the barbs. I'm shocked at the temp drop though with the 1070, I used to be hitting 75c after an hour on Valley and to only see 38c now is impressive.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
