Go Back   OC3D Forums > [OC3D] General Forums > OC3D Member Reviews
Thread Tools Display Modes
  #1
Old 19-06-16, 01:29 PM
Ondoy Ondoy is offline
Newbie
Asus X99-A II Review
Haswell-E launched two years ago, it brought with it a new storage standards to the mainstream and additional PCI-E lanes.
This year Intel launched Broadwell-E and to prepare for this launch ASUS has released several X99 motherboards, one of it is the X99-A II.
Existing products can house the upcoming CPU requiring only a BIOS update.
The X99-A II utilises premium components including an OC socket, DIGI+ power control, T-topology circuit design and Crystal Sound 3 audio solution.
This makes it a good choice for users on a tight/reasonable budget.
Specifications:
Packaging and Contents
The board comes with the following bundle, user's guide, drivers disk, SLI bridge, Q-Shield (I/0), four SATA 6Gb/s cables,
CPU installation tool and extension cable for RGB strips.
Board Pics
The motherboard has a digital 8-phase power design for the CPU, it also adopts a classic black and white color which looks fantastic.
The board has a jet black PCB, asus has also incorporated LED's into the PCI-E slot tabs and an additional lighting from the PCH.
Throughout the board there five fan connectors which can supply up to 3A of power. This board also supports up to 128 DDR4 memory @ 3200MHz.
The top PCIE slot is enclosed in a metal to provide more support.
The heatsink looks like a brushed aluminum with a plastic cover.
It also features a Realtek ALC1150 8-channel surround sound with 112dB SNR outpu and 104dB SNR input, for it's price this is a pretty solid on board audio solution.
Aside from the lighting the board also features a M.2 and U.2 ports as well as SATA Express with 10 SATA 6Gbps ports.
The rear IO has a BIOS flash button, PS/2 keyboard/mouse combo, four USB 2.0, four USB 3.0, USB 3.1 Type-A, USB 3.1 Type-C, S/PDIF optical and 5 audio jacks.
The RGB header is a GRB header
The board also features ASUS OC socket, more info can be found here.
The X99-A is a solid motherboard with a lot of feature, the best board for budget minded users.
The board is fantastic and utilizes premium components including an 8-phase CPU power delivery, OC socket, high endurance capacitors and a thick PCB design.
Pros: Solid motherboard with plenty of useful features
Best board for users with tight/reasonable budget.
Cons: RGB is not everyone's cup of tea
  #2
Old 16-09-16, 02:10 PM
Mike-Irish Mike-Irish is offline
Newbie
A very nicely structured review. I am very interested in the ASUS X99 II Deluxe board. I think that the Deluxe model has allot more extras to off effer like the Firewire unit M.2 Pcie riser card more USB 3 ports and extra Sata cables. I also think that the on board audio is a higher speck one but I might be wrong!! I think it also has extra potential for overclocking bit then again I could be wrong on that one also!
How do you all feel about spending the little extra for the Deluxe model over the "A" model. Should I spend the extra on the CPU. The CPU that I am thinking of going for is the i76859K I don't think that I could stretch to the X chip set.
PS. My main use for this PC will be photo editing and photo storage with lots of 4Tb hard drives in it. I will also have a Samsung 500Bt M.2 and a samsung 256Gb SSd as a scratch disk. I will also fit a 1Tb Samsung SSD later this year for my working folders is Lightroom & photoshop 6CC+ some other photo Post Processing software.
Regards.
Mike
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
