Go Back   OC3D Forums > [OC3D] Project Logs & Gallery > Rig Gallery
Thread Tools Display Modes
  #1
Old 13-01-13, 11:50 PM
R4VANG3R's Avatar
R4VANG3R R4VANG3R is offline
Newbie
R4VANG3Rs Rig - Project Phantom part II
Hey guys!
I've had this case for a while and have done some slight modding on it, I'm kind of new to the whole modding thing though so you have probably seen this a hundred times before, but I still wanted to share my rig with you guys.
The case is obviously a NZXT Phantom (first gen),
and this is what it used to look like some time ago.
So I already did some paint work there, although not everything has been done properly, but that's because I hadn't ever spray-painted anything before.
So.
In the meanwhile I've done quite a bit of modding on the case, didn't photograph everything though..
First of all I wanted to upgrade my rig hardware-wise.
Here's the new specs:
i7 3770K
MSI Z77 MPower
2x4GB Corsair Dominator GT 1866MHz
XFX HD Radeon 7970
Antec H2O 620
Cooler-Master Silent Pro M1000
Samsung 830 Series SSD 128GB
Western Digital Caviar Black 1TB 7200RPM HDD
Already making a lot of mess in my room..
I will be doing a full water loop later on when I have the money for it.
So with that in the back of my mind I wanted to remove the huge HDD Cage inside my Phantom as it's a very nice place to put a 240 rad.
But first, cleaning out my case! And we have a very nice tool for that!
Everything clean!
Lets start drilling.
And out you go.
Small HDD Cage in.
With front fan mounted.
Most of the stuff is in, starting to look good.
RAMs in, damn I love how they look.
So.. now some cable management.
Before:
After:
Now with the PSU Guard my Father-in-law made me, it's made of some kind of steel (can't remember the name)
Well that's it for now, I will Watercool it sometime soon when I get the funds together and will start OCing it then aswell!
So when that time has come I will update this post!
Cheers!
R4VANG3R.
__________________
- NZXT Phantom Black -
- i7 3770k - MSI Z77 mPower - XFX HD 7970 -
- 8GB Corsair Dominator GT 1866MHz - 128GB Samsung 830 Series SSD -
  #2
Old 14-01-13, 01:38 AM
dugdiamond's Avatar
dugdiamond dugdiamond is offline
OC3D Elite
please resize some of the images - they are way too big - thanx
__________________
Prepare for the worst. Assume losing. Then... if the opposite occurs... BONUS!
  #3
Old 14-01-13, 08:00 AM
R4VANG3R's Avatar
Newbie
Resized!
__________________
  #4
Old 14-01-13, 08:26 AM
tinytomlogan's Avatar
The Guvnor
Really need to repaint that mesh dude
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #5
Old 14-01-13, 08:30 AM
Toppy Toppy is offline
Newbie
yeah nice layout that mesh needs another going over me thinks .. but all in all nice clean internals
  #6
Old 14-01-13, 08:54 AM
R4VANG3R's Avatar
Newbie
If you guys are talking about the big red side mesh, then that's a goner!
I made a window there
But it was the first time I ever spray painted anything so that's why it's so bad
And thanks I spent a lot of time on the cable management
__________________
  #7
Old 14-01-13, 05:41 PM
TAWN TAWN is offline
Member
Digging it!! Cable management win.
  #8
Old 14-01-13, 05:59 PM
SimonB's Avatar
SimonB SimonB is offline
Newbie
Send a message via Skype™ to SimonB
yea all are nice i do like build to but your temps should be horible because your fans on rad ar both pulling air and both do pressure to eatch other m8 that brings heat so you not cooling you heating everything there =D so everything is great good job just make push pull not pull pull on rad sry after posting i looked last 2 images there problem is solved
__________________
Too tall - management
keep in mind i use wireless router =D
  #9
Old 14-01-13, 07:27 PM
R4VANG3R's Avatar
Newbie
Thanks
Haha yea I mounted it the wrong way at first but saw it soon enough so I turned it around before I was finished
__________________
  #10
Old 14-01-13, 10:20 PM
Rathy_21 Rathy_21 is offline
Newbie
Sweet rig love the hint of red in there its sets it off nice.
Wheres the pics with the window?
You know you can never post enough pics right?
__________________
CoolerMaster HAF-X|Intel i7 920 @ 4.0ghz 1.285v|Corsair H100|Gigabyte X58-UDR3|Asus Gtx 480|Point Of View Gtx 480|Mushkin 1066Mhz 7-7-7-20|
|Coolmaster Silent Pro 1000w|WD Caviar Black Sata3 1Tb|WD Caviar Blue 500GB x2|Samsung Spinpoint F1 1.5Tb
Tags
gallery, mod, nzxt, phantom, rig
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
