Thread Tools Display Modes
  #91
Old 18-07-12, 11:05 PM
Bullmecha's Avatar
Bullmecha Bullmecha is offline
Advanced Member
Going great G.. keep up the mod work!!
__________________
Asus Z170-A - I5 6600K (OC 4.2) - 16GB Ripjaw V -Sapphire Radeon HD 7870 Ghz - Samsung 850 EVO 120GB - White NZXT 810 Switch
  #92
Old 19-07-12, 12:46 AM
CPMFW's Avatar
CPMFW CPMFW is offline
OC3D Elite
nice work on the fans...
waiting for the next update
__________________
  #93
Old 19-07-12, 06:47 AM
The Orange One The Orange One is offline
OC3D Elite
Send a message via MSN to The Orange One
+ 1
(Message Too Short)
__________________
Broadband, Y U So Slow?
  #94
Old 20-07-12, 08:36 PM
G-Dubs's Avatar
G-Dubs G-Dubs is offline
Advanced Member
Well if you've seen the latest article on the home page by now you'll have already worked out that it's time to add in a bit of the detail and share with you guys what's been keeping me out of Mrs Dubs Hair for a while.
The MSI Z77A GD55 is a cracking motherboard sharing many of the attributes of it's bigger brother, which was the main reason it was chosen for this project. What didn't fit with the theme of the project was the heavy dose of electric blue on all the heatsinks etc.
We decided that nice though the blue was it would have to go. If you want to change the colour of the heatsinks you've got quite a few options, aside from actually swapping them for other heat sinks of course. option 1 is to remove them and paint them, here you do of course run the risk of damage to the motherboard + all the hassle of getting them of (assuming everything you want to change the colour of will actually come off). Option 2 is to mask off and to spray items in situ. i gave this serious consideration, but as my paint shop is essentially a shed with some polythene lining and the weather has been far from clement I chose not to risk it. I was also a little concerned about static build up and discharge harming components. Finally option 3 which is the option of choice. It's the most lengthy and time consuming and does require a great deal of patience and a degree of skill perhaps. If you haven't guessed by now it's all been painstakingly hand painted. Took a good couple of days and 3 coats per item but I'm really quite pleased with the result. I think it really transforms the MSI board. Who knows MSI might even bring out a "G-Dubs Black edition" board.
A few pictures of the board after the first coat and then fully painted and installed. You'll notice the odd bit of blue peeking out on some images, in particular the PCI slots as obviously the inside of these where the connectors live can't be pained. All the other little bits were picked up on the 2nd and 3rd coats.
These also used to be blue.
I spent a good deal of time deciding which fittings to go for, eventually deciding I would spend my hard earned wedge with the great guys at Specialtech, and splash out on some Bitspower fittings. I've always lusted after these and thought I'd treat myself. They didn't disappoint, oh good god no. You had a bit of a sneak peek a few pages back, but here they are in all their naked glory.
Behold watercooling porn (queue 70s wakka wakka music)
thanks you all for taking the time to look. next up will be fitting the excellent razor and raystorm blocks.
See you soon and Mod on Guys.
__________________
  #95
Old 20-07-12, 08:41 PM
Yeren Yeren is offline
Advanced Member
the hand paint job looks good, TBH unless you know you would of thought it came black
__________________
3770k -- Asus P8Z77 V-PRO --
Corsair H100i --
16GB Corsair Dominator Platinum 2133MHz
EVGA GTX680 Superclock Signature 2
AX760i -- 256GB Crucial M4
CoolerMaster Stryker
27" 2560x1440 Monitor
  #96
Old 20-07-12, 09:51 PM
MadMarc's Avatar
MadMarc MadMarc is offline
OC3D Crew
The mainboard looks really nice in black, good job dude!
  #97
Old 20-07-12, 09:58 PM
drunkenvalley drunkenvalley is offline
Member
What sort of paint and tools did you use for the painting of the board?
__________________
  #98
Old 21-07-12, 06:00 AM
PBaines's Avatar
PBaines PBaines is offline
Member
Send a message via Yahoo to PBaines
As above !! really really top notch job on the motherboard!
From this, Maybe I will do this to another blue board but change it to orange
  #99
Old 21-07-12, 06:36 AM
epeets epeets is offline
Member
that board! Holy , that was a good hand job. *insert "that's what she said"* lol
__________________
Current Rig:
PATIENCE
4.6Ghz Custom WaterCooled
  #100
Old 21-07-12, 09:17 AM
G-Dubs's Avatar
Advanced Member
I gave a great deal of thought to choice of paint. Original thought was to use acrylic as it's quite easy to work with and easy enough to remove any mistakes.
However as I wasn't too sure how well it would stand up to even small amounts of heat (is is going on a heatsink after all), I decided to use a product called Humbrol enamel paint. Matt Black 33 thinned by 25% as it's pretty gloopy stuff even when mixed well. A selection of brush sizes with some very small ones to get into all the little nooks and crannies and an awful lot of patience. if you fancy having a go, you can get all this stuff from the sort of places that sell models etc.
I have to say I'm rather pleased with the result and nice to see the work appreciated, thanks Guys
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
