Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 17-08-19, 06:06 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
System Went Pop
So my Crosshair Hero VII board a few minutes ago went pop, 1 of the VRM's around the CPU socket went POOF with magic blue smoke and it took my 3900X with it
Tested my 3900X just to make sure in an X570 board I have, Putting together a build for a friend, And can confirm it's dead, So yeah, Great day........
SO.
I'm weighing up options while I sort out support from Asus considering the board is still within warranty etc... and they'll hopefully help with the CPU considering it was their board that killed it.
Do I stay with AMD or switch over to Intel and get a 9900K ?
Especially considering all I now do on my machine is game and according to all the reviews, Although the 3900X is great, The 9900K is still ahead in gaming especially at my chosen res of 1080P.
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - GTX 1080 Ti FE @ 2000/6000 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #2
Old 17-08-19, 06:23 PM
AMD Enthusiast
9900k is better at gaming. You play at 1080p, so i don't see much of a point for AMD unless you want to support the little guy.
__________________
I am Iron Man.
  #3
Old 17-08-19, 07:42 PM
Eddie long's Avatar
Eddie long Eddie long is offline
Advanced Member
SO.
I'm no intel fan boy but my second system 8700k runs games great at even 1440p
on a side note was reading your post and my main system had a wobble q code A2 followed by AE so i think you jinxed me too
__________________
Life isn't always a bowl of cherry's.
Sometimes it's HARD WORK
  #4
Old 17-08-19, 07:44 PM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
Sorry to hear this bud, hopefully you can get it sorted quick and painlessly soon.
Onto your question, have you considered the 3700X? As for pure gaming, it's a much better value overall. Since anything over 8 cores is just pointless for gaming. ScienceStudio did a good video on it if you're interested:
  #5
Old 17-08-19, 10:25 PM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
I don't know Dicey, do you really want to go back down that rabbit hole again?
Sure the 9900k is faster but it's not that much faster, it's still more expensive, there's no longevity with the socket, it's still vulnerable to all these different attacks so yeah man I wouldn't do it myself, TBH Intel might be worth a look next year when they bring out their new 10nm chips, the mitigation's should be in place, and if they're smart they might extend the life of their sockets to match AMD.
So for the time being I'd just stick with AMD and see what happens next year and then decide.
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #6
Old 18-08-19, 02:51 AM
Dicehunter's Avatar
Resident Newb
I'll have to see, A work friend of mines brother built a dual system rig in a Phanteks I think ? Anyway he built a 3900X and 9900K rig, He uses the 3900X for folding and rendering and 9900K for high refresh rate 1080P gaming so I'm going to compare both in real time in the games I play, Whichever does better will be the choice.
I'll probably end up getting Intel/AMD's next CPU this time next year anyway.
__________________
  #7
Old 18-08-19, 03:17 AM
OC3D Elite
Well if that's the case then I guess whichever does what you need it to ATM and TBH I'd say the Intel chip is going to be quicker for you
__________________
DRAGON'S MIST
  #8
Old 18-08-19, 10:48 AM
Master&Puppet's Avatar
Master&Puppet Master&Puppet is offline
OC3D Elite
Sorry to hear that, hope ASUS help you with the cost.
Honestly I don't think there's much between the two choice wise. You'll get, what 5% more FPS on Intel? But a 9900K is actually cheaper than a 3900X at the moment although board costs may even that up. Maybe whatever ASUS offer you will make a difference.
I upgraded to a 9900k in April and haven't got many complaints but if I had upgraded later, I probably would have gone AMD just to support the competition and feature set they've provided.
__________________
Ivy Bridge Overclocking
Overclocking pt2-LLC & Vdroop
OC3D Overclockers Club Member #006 (Alec Trevelyan was always harder than Bond anyway)
  #9
Old 18-08-19, 11:08 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
It could have been a bad CPU. Just because the VRM is burnt doesn't mean it was the board. I'd return both TBH.
__________________
"Those really high 20 series prices are just place holders"
  #10
Old 19-08-19, 03:48 AM
AMD Enthusiast
If you are going for AMD next year you may as well get AMD now and use the same board next upgrade.
__________________
I am Iron Man.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
