Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #1
Old 03-08-19, 03:40 AM
mutantaxe mutantaxe is offline
Member
best aio 360
Going to put it in the Lian Li PC-O11 Dynamic Tempered Glass Case White and dont really care about RGB...if its there I will use it , if its not there I will just have the minimun RGB on the motherboard
Basically a Black and white build and I want a 360 AIO to mount on the side and will have 6 other fans ( 3 bottom and 3 top ) that will be either RGB or just plain black
So after recommendations for fans and recommendations for AIO
looking through TTL youtube and I cant see any but I do recall he did something about the Asus ROG AIO but that is overpriced ( they seem to add 20% for the ROG brand )
  #2
Old 03-08-19, 07:18 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
I'm a big fan of the NZXT series https://www.nzxt.com/products/kraken-x72 Though not the X72 review this should give you an idea
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #3
Old 03-08-19, 09:13 AM
Dark NighT's Avatar
Dark NighT Dark NighT is offline
OC3D Elite
I would say give the Fractal Celsius 36 a look, it's all black, no lights, neat cable management and not to overpriced.
  #4
Old 04-08-19, 09:21 AM
Dawelio's Avatar
Dawelio Dawelio is online now
OC3D Elite
Yeah, I’d give the Fractal Design Celsuis S36 a look, very minimalistic and sleek design.
  #5
Old 04-08-19, 02:11 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Basically all the 360 AIO's are the same minus 1 or 2 differences, The real performance difference comes from the fans.
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - GTX 1080 Ti FE @ 2000/6000 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #6
Old 04-08-19, 06:54 PM
looz's Avatar
looz looz is offline
OC3D Elite
What kind of a CPU will you have? If Ryzen 3, buy a big air cooler IMO. AIOs are louder and have more parts prone to failure. Mugen 5 fits nicely, for instance.
__________________
i7 8700k - 16GB - 2060 FE - 512GB 970 & 850 EVO - AKG K702
  #7
Old 04-08-19, 11:04 PM
Dawelio's Avatar
OC3D Elite
In most cases and in this certain one yes... But in my case for example, that is a bit more complicated.
  #8
Old 15-08-19, 09:29 AM
Member
well have gone for the Thermatake 360 rgb sync aio and will but that in the top of the case which is now the black version along with 6 case fans ( noctua black a12's ) and have them all on order......have also ordered the 3900x ( they are sold out at the moment ) so it wont be until end of month before I get that.....
only one more bit of kit to get and thats the motherboard..........waiting for TTL to put up more z570 mobo reviews
  #9
Old 02-09-19, 05:45 AM
Member
and an update...hate the Thermaltake 360....the cables are long enough to go around the bloody case, just what you need in a case, more cabling to hide so followed advice and got the Kracken X72 and have to admit the pump head looks pretty good but its a pain attaching to a Aorus X570 Master.....getting the hook attachment on was not a happy experiience..no idea if there was a fault with the motherboard or my fingers.
and 3900X have dried up......so ended up with a 3700x
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
