Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #21
Old 13-08-19, 06:42 PM
NeverBackDown NeverBackDown is online now
AMD Enthusiast
Originally Posted by Bartacus View Post
Gigabyte has impressed the HECK out of me with this board. They implemented a silent mode for the chipset fan, but I found out it was NOT the chipset fan that was bugging me. Apparently one of my 3-pin Gentle Typhoons might be on the way out. That's the problem when you have 17 fans in a case and something makes a small annoying noise. I narrowed it down to one bank of fans on one of my 360 rads, so the chipset fan is innocent of all charges!
I think you need more fans. 17 is not enough
__________________
I am Iron Man.
  #22
Old 13-08-19, 06:45 PM
Bartacus Bartacus is offline
OC3D Elite
Don't tempt me! My 240 rad has a reservoir hanging off it that doesn't *quite* stick out enough in the windowed area of my case, and adding a second set of fans would fix that quite nicely!
__________________
Guts: Ryzen 3900X / GB Aorus Master / 16GB TridentZ 3600CL15 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: Corsair Force MP600 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 240 rad / Heatkiller reservoir / dual D5 pumps
  #23
Old 13-08-19, 07:22 PM
AMD Enthusiast
Speaking of fans and GT's specifically. I had 6 and put them away as I got some Noctua's instead in a 140mm size, and recently I wanted to use them again and apparently they grew legs because I cannot find them ANYWHERE lol
I opened every box and drawer I have ever used for computer stuff and they just vanished
__________________
I am Iron Man.
  #24
Old 13-08-19, 07:39 PM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
Yeah, cause you put them away in the garbage can
  #25
Old 16-08-19, 02:31 AM
mutantaxe mutantaxe is offline
Member
I am thinking having 3 x 120mm fans in the bottom with blow enough cool air over my NVmme drive and chipset to keep them cool
  #26
Old 17-08-19, 06:23 PM
Zoot's Avatar
Zoot Zoot is offline
OC3D Elite
I have this board:
https://www.overclock3d.net/reviews/..._itx_preview/1
The 2nd BIOS released for the board added profiles and custom fan curves for the chipset fan. After living with it for a weekend, I think the chipset fan (at least on this board) is a total non-issue. I can't hear it over the rest of the fans. I think it's more there for the M.2 drive than the chipset itself.
I have the Aorus PCIe 4.0 1TB M.2 drive and the fan is actually a good thing to keep that thing cool because it does run quite hot.
__________________
Desktop: AMD Ryzen 7 3700X | X570i Aorus | 32GB Corsair DDR4-3200MHz | RX 5700 XT | Aorus PCIe 4.0 1TB M.2 | Fractal Define Nano S
Home Server: AMD Ryzen 3 2200G | Asus Prime B450M-A | 16GB Crucial DDR4-2400MHz | 39TB | Fractal Design Define R5
HTPC: AMD Athlon 5350 | ASRock AM1H-ITX | 4GB Corsair DDR3-1333MHz | MiniBox M350
Tags
chipset fan, fan noise, x570
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
