Go Back   OC3D Forums > [OC3D] Customer Care Forums > Asus UK Customer Care Forums
Thread Tools Display Modes
  #1
Old 22-06-19, 02:01 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Aura Not Working
Out of nowhere Aura is not working, Nothing on my system has changed, Tried uninstalling Aura, Re-installing, Using an older version, Nothing, It simply refuses to work, Kind of annoying as now my ROG motherboard is doing the whole rainbow puke thing.
It seems Asus software is a bit of a time bomb going from my own and other peoples experience, Ok for a while and then refuses to work for unknown reasons.
__________________
=Origin-Steam-Uplay-XBLive - Dicehunter=
  #2
Old 22-06-19, 06:10 PM
Eddie long's Avatar
Eddie long Eddie long is offline
Advanced Member
when that happened to me i had to refresh windows and re install aura , not sure if that was the correct way but it worked
__________________
Life isn't always a bowl of cherry's.
Sometimes it's HARD WORK
  #3
FTLN FTLN is offline
OC3D Elite
check the logs in /appdata
__________________
Intel Core i9 7980xe @ 4.5GHz @1.18v - MSI MEG X299 - NoName 2666mhz @ CL19 3200mhz - Thermal Take View Glass - PM961 1TB x2 - Aorous Extreme RTX 2080 Ti - 2 x 360 Rad + D5 Pump - Asus ROG Swift PG279Q 2560x1440P G-Sync 165Hz
  #4
Old 22-06-19, 08:10 PM
Bartacus Bartacus is offline
OC3D Elite
Any Windows updates recently? I just downloaded the latest big one, and (shocker) it actually FIXED something, a weird reboot issue I had where the system would never restart, just shut down. The latest Windows 10 major update wouldn't install without a newer AMD RAID driver (and I had the latest on Asus website). So the update had a link directly to AMD, where I nabbed a newer RAID driver, problem solved.
I only mention this here because it's an Asus board (Crosshair 7 Hero). The update never messed with my Aura though.
__________________
Guts: ThreadRipper 2950X / GB Aorus Xtreme X399 / 64GB TridentZ Royal 3600CL16 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU
Storage: 6TB RAID0 NVME array (ADATA SX9200 Pro 2TB x 3)
Water Cooling: HeatKiller TR4-Pro CPU block / HeatKiller IV GPU blocks / 360mm Darskide LP360 rads x 3 / Heatkiller reservoir
  #5
Old 22-06-19, 08:16 PM
Dicehunter's Avatar
Resident Newb
I formatted and reinstalled windows, Now it works, I like Asus hardware but their software is pure ass.
__________________
  #6
Old 22-06-19, 10:11 PM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
What an joy knowing that an formatting and reinstalling of Windows will fix something...
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
