Go Back   OC3D Forums > [OC3D] Customer Care Forums > Asus UK Customer Care Forums
Thread Tools Display Modes
  #1
Old 27-03-19, 02:38 PM
AlexB AlexB is offline
Newbie
Question Asus Maximus XI Gene and Aura LED's ???
Hi Peeps,
I guess there must be a few people using the Asus Aura software to control the lighting in their cases but what brand led strips do people recommend to use ? I'm not looking to have the unicorn puke look inside my case (not my thing) but a strip across the roof and one down the side so I can see the goodness behind the tinted perspex
The Led headers on the Maximus XI Gene are the 4 pin which only support non addressable 5050RGB LED strips with a maximum power rating of 12V/2A.
Feel free to point me in the right direction
Rig Spec's so fare -
CPU - Intel Core i7-9700K @5.1GHz (Coffee Lake)
Motherboard - Asus Maximus XI Gene
Ram - G.Skill Trident Z RGB 16GB Kit DDR4 3200MHz RAM
GPU - EVGA GeForce GTX 1080Ti SC2
PSU - Asus ROG Thor 850W 80 Plus Platinum
CPU cooler - ASUS ROG Ryujin Performance AIO
Case - Cooler Master MasterBox Lite 3.1 mATX Case
  #2
Old 27-03-19, 05:17 PM
Warchild Warchild is offline
OC3D Elite
Hmm I dont use them now, but I tested the Corsair strips that came with my 1000D and they seemed to work well on my ASUS board.
  #3
Old 28-03-19, 03:45 PM
Newbie
How long ago was that ? would you have a link to them ?
Thanks Al
  #4
Old 28-03-19, 05:19 PM
Bartacus Bartacus is offline
OC3D Elite
Your motherboard manual should have details on that, no? My Crosshair 7 Hero has the specs listed in the manual, supported RGB LED type, max amperage, etc.
__________________
Guts: Ryzen 2700X / Asus CH7 Hero / 32GB TridentZ RGB 3200CL14 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: ADATA SX8200 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads / Barrow box reservoir / dual D5 pumps
Tags
asus, aurs, maximus xi gene, rgb
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
