Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 16-03-19, 09:46 PM
RobCharles1981 RobCharles1981 is offline
Member
Clock Watch Dog Time Out BSOD
Hi all I'm wondering if you can help me with this problem?
I've basically gone ahead and upgraded my Computer with this:
AMD Ryzen 5 2600
MSI B450 Gaming Plus (Latest Bios)
Corsair 16gig 3200 Memory
I've installed Windows 10 and the motherboard drives and graphics ect.
But after sometime my system freezes with no reason, and then I get a BSOD with "Clock Watchdog Timeout Ryzen"
Any idea what this means and how can I fix this?
Thanks
Rob
__________________
AMD Ryzen 5 2600. MSI B450 Gaming Motherboard Corsair H60, Corsair Vengenance LPX 16gig DDR3
Corsair TX 750m PSU, AMD R9 390: Creative Soundblaster Z: Fractal R5 Case
  #2
Old 16-03-19, 09:57 PM
tgrech tgrech is offline
OC3D Elite
Watchdog timers just check whether or not a system has froze and triggers a BSOD/reset if so, I'm afraid that BSOD message won't be much use in finding the cause of the freezing on its own.
Chipset/CPU drivers are a good place to start though(Might need a reinstall or similar), if you're on latest Win10 build already.
  #3
Old 16-03-19, 11:17 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Is your memory Bdie? is it set on AXMP?
__________________
  #4
Old 16-03-19, 11:41 PM
Member
Hi this is my memory.........
https://www.novatech.co.uk/products/...2b3200c16.html
__________________
  #5
Old 17-03-19, 02:39 AM
AlienALX's Avatar
OC3D Elite
I can't verify if that's Samsung or Hynix.
Download CPUZ, go to SPD and look at this and see what it says.
99.9% of the issues with Ryzen are memory related.
__________________
  #6
Old 17-03-19, 11:34 AM
looz's Avatar
looz looz is offline
OC3D Elite
It isn't b-die, b-die 3200MHz would be CL14.
__________________
i7 8700k - 16GB - 2060 FE - 512GB 970 & 850 EVO - AKG K702
  #7
Old 17-03-19, 02:21 PM
Member
Hi all please find attached info from CPUZ.
Many thanks!
Click image for larger version
Name:	BSOD Problem.jpg
__________________
  #8
Old 17-03-19, 02:22 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
Really hard to diagnose this one
The Ram is Hynix and is not on the compatibility list from what I can see for that board, however that should not mean it is unusable.
Try the following
  • setting your ram to its normal JDEC i.e turn off XMP
  • Open device manager and expand Computer right click ACPI x64 > Select update driver and search auto
  • Do this again with the following devices
  • Display adapters
  • monitors
  • network adaptors > Realtek
I have a feeling that lower Ram speeds will be what fixes it though
__________________
ASUS Prime x370 Pro | Ryzen 5 1600 | Antec 240 AIO | Corsair Vengance RGB 3000 2 x 8Gb | Asus Strix RX 470 | Samsung Evo 120gb ssd | Seagate Baracuda 1tb storage | EVGA 500w | Phanteks Entho ProM Acrylic Window | Windows 10 and Linux Manjaro
  #9
Old 17-03-19, 02:33 PM
Member
Another Update - I asked in another forum who told me to download an an application "Who Crashed" this is the report that it's given me......
On Sun 17/03/2019 08:42:40 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\031719-8796-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x14CC20)
Bugcheck code: 0x101 (0x10, 0x0, 0xFFFFD00160DD8180, 0xA)
Error: CLOCK_WATCHDOG_TIMEOUT
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that an expected clock interrupt on a secondary processor, in a multi-processor system, was not received within the allocated interval. This can be caused by non-responding hardware or by a overheated CPU (thermal issue).
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
__________________
  #10
Old 17-03-19, 03:39 PM
AlienALX's Avatar
OC3D Elite
All that means is that the timing in your kernel got waffy dude. It could have been for many reasons, but mostly CPU and RAM speed. I've had Watchdog errors on boggy stock rigs.
I would surmise it is your RAM causing the issue, as 3200mhz non Samsung is pushing it. Try tweaking it back to around 2900 and see what happens then.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
