Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 01-03-19, 08:05 PM
Pugsport Pugsport is offline
Advanced Member
on board AMD or Intel graphics
hello all
i just wanted to ask if anyone here knows or uses on board graphics to run sketchup at all?
wanting to build a workshop pc and would rather not have to use a GPU just for sketchup if i dont need to as this will be the most demanding thing this pc will need to do as the stuff will be mainly website browsing, playing music/radio and maybe some tv
any help and advice would be great
thanks
  #2
Old 01-03-19, 08:47 PM
looz's Avatar
looz looz is offline
OC3D Elite
R3 2200G should be perfect on paper, though I do not know about SketchUp specifically.
__________________
i7 8700k - 16GB - 2060 FE - 512GB 970 & 850 EVO - AKG K702
  #3
Old 02-03-19, 09:44 AM
tgrech tgrech is online now
OC3D Elite
Yeah SketchUp runs fine on my laptops Intel HD4000 (Ivy Bridge iGPU) and there's no real notable difference in usability for SketchUp when I connect up the external GPU and use that instead (HD7870XT) so any modern iGPU from either company will handle it fine. I'd recommend you have at least 8GB of RAM though as SketchUp eats this already and using an iGPU will take upto another 1GB of RAM for VRAM so 4GB would probably cause issues.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
