Go Back   OC3D Forums > [OC3D] Graphics & Displays > Overclocking
Thread Tools Display Modes
  #11
Old 07-03-19, 10:42 AM
WYP's Avatar
WYP WYP is offline
News Guru
Originally Posted by KingNosser View Post
Thanks in bios it's set to 1.35 and LLC mode2 it bumps up a bit under full load but not constant just now and then like in cinebench r20 the sofa white fabric seems to be the intensive part. I just need to do a longer session of Prime95 then but thanks for letting me know makes me feel more positive over running that voltage.
I have been hearing that the new Cinebench is a great test for Ryzen OC stability. OCCT is also a good shout. If you can run 30 minutes to an hour in there, you are probably good to go.
__________________
_______________________________
Twitter - @WYP_PC
Tags
amd, cinebench, overclocking, ryzen, zen 2
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
