Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #11
Old 05-02-19, 06:15 PM
tgrech tgrech is offline
OC3D Elite
FPS varies per games & settings, no one can give you an estimation numbers wise. Best to just look at a variety of benchmarks for the cards you're considering & games you play, even an RX590 can get certain games into the 100's at 1080p max settings, and with some sensible settings tweaks can probably get almost any game there, given all these cards you're looking at are notably more powerful you should easily be able to get [email protected] on any game that isn't CPU limited with any card from V56/RTX2060 up without turning down anything you'd notice.
No one can tell you what the performance difference is worth though, that's a personal question.
  #12
Old 05-02-19, 06:24 PM
mikedf mikedf is offline
Newbie
i have this monitor https://www.asus.com/Monitors/VG279Q/ so in 1080p with 4770k or zen 2 or 9900k with one rtx 2070 and 2080 what fps i will have in all these situtations?/
if we calcuate all these things in average? with all these 2 cpus and my monitor which have and with these 2 cards rtx 2070 and 2080?
can you answere me in all these things p[lease? because in 2 hours i will have to order new gpu..
i mean what performance has rtx 2070 againsti rtx 2080 in 1080p;;
is it worth to buy rtx 2080 for 1080p?>
for 1080p which to buy rtx 2070 or rtx 2080?
this i mean
and if i will buy rtx 2080 will i see boost in fps against rtx 2080 in 1080p;
because some people say that rtx 2080 is not for 1080p for this i am asking what to do?
  #13
Old 05-02-19, 09:43 PM
russler russler is offline
Member
2080 deffo unless you can stretch to ti then even more frames imagine that.
  #14
Old 06-02-19, 03:49 AM
looz's Avatar
looz looz is online now
OC3D Elite
what?
__________________
i7 8700k - 16GB - 2060 FE - 512GB 970 & 850 EVO - AKG K702
  #15
Old 06-02-19, 04:52 AM
MacLeod's Avatar
MacLeod MacLeod is offline
OC3D Elite
Yes you should buy a 2070 especially for that monitor. It'll give you plenty of horsepower to take advantage of the 144 Hz refresh rate and Nvidia cards now work on most FreeSync monitors.
A 2070 might technically be overkill for 1080 but in 4 years when you still don't need to upgrade, you'll be glad you went overkill. Or if you ever decide to jump to 1440 you'll have plenty of GPU to handle it.
__________________
AMD R5 1600X @ 4.0 GHz ••• Asus ROG Strix X370-F ••• Corsair H110i
Corsair 500R ••• EVGA Supernova G3 750 ••• Corsair Vengeance 16GB
Western Digital Caviar Black 1TB x2 ••• Nvidia RTX 2070 FE
Samsung 840 Evo 250GB ••• Acer Predator XB272 @ 240 Hz
Logitech G-Pro TKL ••• Logitech G MX518
  #16
Old 06-02-19, 04:34 PM
Newbie
this i mean
what you mean when you say A 2070 might technically be overkill for 1080 ?
if i will buy a 2070 for 1080p how long will last me for to play games in ultra settings? 3 years or less?/
i was thinking to buy rtx 2080 because now i know that is overkill for 1080p but after 2 years the rtx 2080 will be standar for 1080p? do you agree?
also how fast is rtx 2080 agaINST 2070? ? in 1080p;/?
ALSO I HAVE ONE ANOTHER QUESTION NOW I HAVE ONE 4770K BUT IN SOME MONTHS I WILL BUY NEW CPU AND ETC
SO MY QUESTION IS with 4770k with these 2 cards rtx 2080 and rtx 2070 in 1080p
what fps i will have with rtx 2080 and what fps i will have with rtx 2070; with the monitor which i have now?
this i mean.
and if i will buy new cpu lets say 9900k what fps i will have with rtx 2080 and what fps i will have with rtx 2070; with the monitor which i have now?
  #17
Old 06-02-19, 05:27 PM
OC3D Elite
You will see more FPS yes, but the difference won't be as big as if you were at a higher resolution, what someone means by overkill is that it's likely to get such high FPS on even the most demanding games or use such high settings that it doesn't deliver a perceivable benefit in current titles. Like you say, sometimes it might be a 20FPS difference, which could be a big deal if that's 40fps vs 60fps but you're much less likely to notice if it's say 100FPS vs 120FPS.
  #18
Old 06-02-19, 05:54 PM
Bartacus Bartacus is offline
OC3D Elite
The bolded point deserves to be emphasized. Most people that focus on benchmarks from websites / YT channels are too focused on the bar graphs, not the NUMBERS BEHIND those graphs. A chart showing a 120FPS comparison to 100FPS can be made to LOOK like a huge difference because the bar is longer. But gameplay wise, it's hardly any difference at all.
__________________
Guts: Ryzen 2700X / Asus CH7 Hero / 32GB TridentZ RGB 3200CL14 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: ADATA SX8200 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads / Barrow box reservoir / dual D5 pumps
  #19
Old 06-02-19, 06:21 PM
Newbie
i want to see this video with one person he compares in games in 1080p with rtx 2080 with 2600k against 9700k,, but this person he is using one monitor which has 60 refresh rate..
and i want to calcuate how many fps will i have with rtx 2070 with my 4770k and my monitor which is 144 mhz?
this person he has botle but also he has monitor which is 60mhz
so with my 4770k and rtx 2070 and 144 mhz refresh rate what fps i will have?>
  #20
Old 07-02-19, 02:13 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
Mike, several people have explained and advised you on the correct card for your needs yet you keep going on about 2070 and 2080 so just go an get a 2080 and be happy.
__________________
ASUS Prime x370 Pro | Ryzen 5 1600 | Antec 240 AIO | Corsair Vengance RGB 3000 2 x 8Gb | Asus Strix RX 470 | Samsung Evo 120gb ssd | Seagate Baracuda 1tb storage | EVGA 500w | Phanteks Entho ProM Acrylic Window | Windows 10 and Linux Manjaro
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
