Thread Tools Display Modes
  #21
Old 26-01-19, 08:36 AM
Wolvie1987 Wolvie1987 is offline
Newbie
so all seems to be going ok at the minute with the spare PSU, as I dare not put the new psu back in I am going to RMA and get them to test it.
Also at the moment I dare not turn on XMP
  #22
Old 26-01-19, 11:35 AM
Dark NighT's Avatar
Dark NighT Dark NighT is offline
OC3D Elite
Love it when i'm right!
Seriously tho, try xmp, run stuff as it's rated to run and you should be fine.
  #23
Old 27-01-19, 05:21 PM
Newbie
Its back
Been playing all day then 2 in the space of 5 minutes
  #24
Old 27-01-19, 05:27 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Did you run a memory test? memtest will do.
__________________
  #25
Old 27-01-19, 06:15 PM
Newbie
I ran the windows mem test? yeah
did a restart and its alright again.......really weird
  #26
Old 27-01-19, 06:17 PM
AlienALX's Avatar
OC3D Elite
Yes it's a DOS based app you need to reboot into. Did it find any errors?
__________________
  #27
Old 28-01-19, 05:03 PM
Newbie
I did, all blue screen mem test thing 100% no problems
  #28
Old 04-02-19, 05:07 PM
Newbie
Turns out everything crashes randomly apart from The Sims 4
going to try a new GPU
  #29
Old 04-02-19, 05:30 PM
Dark NighT's Avatar
OC3D Elite
I thought this was solved, but huh..
Hope a different gpu helps.
  #30
Old 04-02-19, 09:23 PM
Newbie
Not solved im afraid i really am clutching at straws.
I have a gtx970 spare so im going to try that see if it still does the same thing, if it dosent i guess ill have found the problem
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
