Thread Tools Display Modes
  #1
Old 06-12-18, 07:13 PM
firstbuild firstbuild is offline
Newbie
ASRock Z390 Extreme 4 or ASRock Z390 Taichi.
Hi, its been a while since I posted but always dropped in to have a look around
I'm going for a new build hopefully after Christmas.
for video editing and encoding.
Its down to these two boards but not sure what one will be best for me
ASRock Z390 Extreme 4 or ASRock Z390 Taichi and I'm not sure if I should go for the 8700K or the 9700K.
I don't plan in overclocking, well, if its easy to do but more important to me is having a rock solid stable workstation.
Thanks in advance.
  #2
Old 10-12-18, 05:52 PM
Newbie
There's over £80 the difference between the two boards, what will I be loosing out buy going for the Extreme 4?
Thanks in advance.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
