Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #11
Old 28-11-18, 01:42 PM
Warchild Warchild is offline
OC3D Elite
Yep, Heaven and Valley are nice tests to run in a loop for 30mins or so.
  #12
Old 28-11-18, 02:05 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Originally Posted by Kaapstad View Post
If your Radiator is getting hot after 5 mins the loop is working and the problem is somewhere else.
Don't use Furmark for testing as it kills GPUs and any results you get from it are pointless anyway as some vendors get their cards to throttle when it is detected.
Test your GPU using something like Unigine Heaven 4 on max settings for 30mins.
If your rad is getting hot maybe you should be looking at trying a bigger one and better fans. 2080 Ti cards can produce a lot of heat but having said that a 240mm rad should be up to the job.
How're your cards holding up ? Gonna put them under water ? I know the FTW3 Ultra cooler is really good but would love to see temps etc... on those bad boys, Unleash the beast as it were
__________________
Steam: Dicehunter
Origin: Dicehunter
Uplay: Dicehunter
Battle.Net: Dicehunter#2746
  #13
Old 28-11-18, 02:19 PM
Kaapstad's Avatar
Kaapstad Kaapstad is offline
OC3D Elite
Coolers are very good and as I will be using them mostly for gaming I will leave them on air.
When the fans turned up and the cards overclocked I can keep the temps on both cards under 60c which is pretty good for an SLI setup where the top card always gets to run a bit warm.
__________________
OC3D Overclockers Club Member
#041
GTX 960 owner and proud of it.
  #14
Old 28-11-18, 02:20 PM
Dicehunter's Avatar
Resident Newb
60'c is a good temp, I was tempted by the FTW3, My finger was hovering over the buy button but I exercised self control for once
__________________
Steam: Dicehunter
Origin: Dicehunter
Uplay: Dicehunter
  #15
Old 29-11-18, 08:47 AM
OC3D Elite
What happened to the "im holding onto my money"
I knew you couldnt resist. Colleague of mine tried RTX in BF 5 with a 2080ti and couldnt cope with the fps tanking down to 38fps...
  #16
Old 29-11-18, 01:12 PM
Dicehunter's Avatar
Resident Newb
Never said I bought it, I was close though
__________________
Steam: Dicehunter
Origin: Dicehunter
Uplay: Dicehunter
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
