Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #11
Old 13-10-18, 02:36 PM
Korreborg's Avatar
Korreborg Korreborg is offline
OC3D Crew
It depends on your view on noise.
Will i do the job = Yes
Will it be noisy = Yes
It's really quite simple. You generate X amount of heat. That heat needs to be dissipated.
A rads ability to dissipate heat is the down to size, fan speed and dT(delta temp).
https://www.ekwb.com/blog/radiators-part-2-performance/
Keep the dissipated wattage above the generated, and you are home safe.
But the 1080ti is 250w TDP and the 8700k is 95w with an OC that's 400w or more.
That 2200rpm or so according to the EK link, if you can keep the deltaT at 10c.
2200rpm is too much for my likings, but it's up to yourself. If you go for it, get a way to monitor your water temp. You need to keep it below 50c to not kill the pump over time. Personally i would keep it below 40. And the lower the better.
__________________
[I9-7900X][Asus Strix X299-E][EVGA 1080TI FE][Corsair 16GB 3733MHz][Fractal Meshify C][Corsair AX860i]
[Samsung 970evo 500GB+1000GB of mixed SATA SDD's][ASUS PG278QR][Logitech G510s and G502][Steelseries Wireless H]
  #12
Old 13-10-18, 02:51 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
You could possibly get away with it but you would need to forget overclocking and undervolt etc. Certainly not a performance set up.
__________________
"Those really high 20 series prices are just place holders"
  #13
Old 13-10-18, 03:05 PM
steverebo's Avatar
steverebo steverebo is offline
OC3D Elite
Yeah I'm gonna go for a phanteks evolv matx case and put my itx board in it hopefully it won't look too out of place I recon I can get away with the psu although it is very small and i can stick a pair of 240 rads in it which should cool it much more efficiently.
Now I need to try and sell my evolv shift x and radiators as my current 240 rad is far too thick for the evolv matx front or top.
I guess this is a lesson learned. Next time I will do my research properly
__________________
BeQuiet Darkbase Pro 900 | i7-7700K OC @ 5.10GHz | Custom water loop | ASUS MAximus Hero IX Z270 | Aurous Xtreme GTX 1080TI @ 2120mhz 12000mhz | 16GB Corsair Dominator Platinum @ 3200MHz CL15 | 500GB Samsung 960 Evo, 250GB Samsung EVO 850 | Corsair HX750I PSU | Windows 10 Pro 64-bit
  #14
Old 14-10-18, 08:52 AM
Ady6UK's Avatar
Ady6UK Ady6UK is offline
Member
The
PC-Q37 by Lian Li will take your single thick rad in the top. I've also seen some creative rad mounting in the bottom of that case too. Just a thought.
Edit: these score well so maybe one of these in the bottom? https://www.techpowerup.com/reviews/XSPC/TX360/
Of course the 240mm version for you.
__________________
Thermaltake View 31 case, i7 8700K, Asrock Z370 Taichi mobo, 32Gb (4x8Gb) G Skill DDR4 3200mhz ram, Samsung PM981 1Tb Nvme M.2 ssd with EK heatsink, WD Blue 3D NAND SATA M.2 2Tb with EK heatsink, 3 Tb Toshiba External HDD, EVGA GTX 1080Ti SC2 Black Edition gpu, Corsair HX750i Platinum PSU, fully watercooled.
  #15
Old 14-10-18, 09:17 AM
Warchild Warchild is offline
OC3D Elite
you want 120mm rad for every component in your loop.
a 240 will work, but you will be pushing it. And your temps will be on the higher side since there isnt enough watt dissipation. Your fans would need to work hard.
i'd say a 360 minimum simply to deal with the overclocks.
2x 240 rads.. easily manageable.
  #16
Old 14-10-18, 09:27 AM
steverebo's Avatar
OC3D Elite
Yeah I put it all together yesterday just to see and you guys are right it's doable but the temps are not what I want and my fans are working overtime. Shame because it looks stunning.
I've put some of my bits up for sale in the marketplace I'm going to go back to full size atx and an evolve atx case with a pair of 360 rads that should sort it.
__________________
  #17
Old 14-10-18, 07:40 PM
Davva2004's Avatar
Davva2004 Davva2004 is offline
OC3D Elite
Do you have the option of running the GPU on air if you turn it around so that the fan faces inwards, and liquid cool the CPU only? If it's a reference design 1080TI then you can use a bottom fan on the case as intake, the GPU will suck it in and exhaust out the top of the case.
Edited to add - the Shift X can also fit a 120mm radiator in the bottom if that helps - either a single 280 in the front, or a combo of 240 fromt and 120 bottom depending on thickness.
__________________
  #18
Old 15-10-18, 09:18 AM
OC3D Elite
What about adding a single 120mm rad mounted where the exhaust fan is?
  #19
Old 15-10-18, 10:38 AM
steverebo's Avatar
OC3D Elite
I actually did that and placed a 120slim at the bottom and it made zero difference to temps if anything they got slightly worse due to the design of the case it was either pulling the warm ambient air from inside the case or pushing warm air into my 240 rad
__________________
  #20
Old 15-10-18, 12:23 PM
Bartacus Bartacus is offline
OC3D Elite
This used to be the old standard, back in the days of dual and quad core CPUs. But I don't think you can really go by that anymore, as a single 120 is not enough rad space to cool an 8 core+ CPU. Even if you're not OCing, your CPU is OCing itself by turbo boosting even in stock configurations.
__________________
Guts: Ryzen 2700X / Asus CH7 Hero / 32GB TridentZ RGB 3200CL14 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: ADATA SX8200 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads / Barrow box reservoir / dual D5 pumps
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
