Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #1
Old 23-07-18, 07:48 AM
tolagarf's Avatar
tolagarf tolagarf is offline
OC3D Crew
Controlling Fan Speed Using Temp Sensor with BIOS
So I have a temperature sensor attached to my water loop and I wanted to adjust my fan speed depending on the water temperature through the BIOS, but I can't seem to get the fans to react to it, at all.
Motherboard is an ASUS Z270 TUF Mark.1, and the temp sensor reports lowest temps at 37C and highest at 45C. So I set up a curve in the BIOS selecting the source as Temp Sensor 1 where it's located, I can see the BIOS reporting a temperature, but there is absolutely no reaction from the fans at all. I used HWInfo to check the temperatures going up while stress testing the system, so it's not like the temp sensor isn't working.
I used the following PWM curve in the BIOS
PWM connector: Chassis Fan 2
Source: Temp Sensor 1
Max: 50C / 60% duty cycle
Middle: 45C / 50% duty cycle
Min: 38C / 25% duty cycle
So what's going on here? Is the BIOS just failing to control the PWM curve when Temp Sensor is selected as source? I'm starting to wonder if this is the case, or something else is happening I haven't thought of.
  #2
Old 23-07-18, 09:36 AM
Warchild Warchild is online now
OC3D Elite
You can do it via external controllers like aquaero but I recall I had to install the AIsuite that came with my Z97 TUF to do it via mobo
  #3
Old 23-07-18, 10:16 AM
tolagarf's Avatar
OC3D Crew
I got it working, it was a stupid mistake of my own doing
Before I controlled my fans with SpeedFan dependent on GPU temperature, and even though I disabled that part, I was still using SpeedFan to monitor fan RPM's. As it turns out SpeedFan had taken full control of the PWM on that fan connector, hence the fan speed never changed.
It's working now, but now I'm dealing with fans ramping up/down on the 43C degree marker on the water temp. Not sure why the heck that happens, even though I set the fans to ramp its speeds up/down with 12/25 seconds in the BIOS. Will probably require a lot of experimentation
  #4
Old 23-07-18, 10:37 AM
OC3D Elite
sounds like its not set as a curve but more as a step profile.
  #5
Old 23-07-18, 10:43 AM
tolagarf's Avatar
OC3D Crew
Hmm.. It's possible. Might require AI Suite to do that, but I really don't like that software. I guess if I want proper control, buying an Aquaero 6 is the best option. It's something I've been considering for some time
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
