Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #11
Old 22-07-18, 01:35 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
When you wash out a rad you need to flush it properly. IE - bleed it so that the flush takes out everything in there. If you get a pocket with something nasty in it it will stay there.
You don't need blitz. That is just acid, quite dangerous and only makes you think you are really cleaning out the rad because it comes out blue/green. That is what copper will do when faced with acid all day long.
IMO? use white vinegar. Flush the rad out with cold tap water (limescale finds it very hard to form in cold water you see) and then shake the crap out of it over a bath and put it somewhere warm so it can dry out.
I've used that method on four loops, and with XSPC EC6 running (in green, red and clear) I have had 0 problems with anything in the loop at all, apart from the time I used Mayhem's Pastel and it went from red to burgundy. Crap, basically.
__________________
"Those really high 20 series prices are just place holders"
  #12
Old 23-07-18, 09:42 AM
SuB's Avatar
SuB SuB is offline
The Webmaster
Warm white vinegar, non dilute, let it sit for 5-10 minutes... can't beat it.
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
