Go Back   OC3D Forums > [OC3D] Customer Care Forums > NZXT Forum
Thread Tools Display Modes
  #1
Old 21-05-18, 03:44 AM
Rob3984 Rob3984 is offline
Newbie
Kraken 62 and NZXT Phantom PHAN-002
I have the above Phantom Case and can’t figure out where or how to mount the radiator. I had no problem with my other Phantom Case but this seems smaller. I mounted the kraken in my other case with the top radiator removed but this doesn’t seem to work. Any help is both needed and appreciated. A speedy reply is needed as I have no PC.
Thanks
Please close thread.
  #2
Old 21-05-18, 04:38 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
From what I can see there is nowhere to mount in that case apart from maybe on the door, the only other way you maybe able to mount it, is to rig it somewhere with cable ties.
Or it might be time to update your case to one that supports a 280 rad.
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 3700X=MSI MPG X570 Gaming Pro Carbon WiFi=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= Sapphire RX5700XT Nitro Plus=NZXT Kraken X62=MSI Optix MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
