Go Back   OC3D Forums > [OC3D] Forum Teams > [OC3D] Gaming
Thread Tools Display Modes
  #51
Old 08-03-18, 02:50 PM
Bartacus Bartacus is offline
OC3D Elite
It also great when you approach a space station from the wrong side, or when you have no idea where the landing pad is. Let the computer take care of it, while you refill your wine / beer / snacks!
__________________
Guts: Ryzen 3900X / GB Aorus Master / 16GB TridentZ 3600CL15 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: Corsair Force MP600 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 240 rad / Heatkiller reservoir / dual D5 pumps
  #52
Old 08-03-18, 02:56 PM
Tolemac's Avatar
Tolemac Tolemac is offline
OC3D Elite
Just trying it out gotta set up the voice pack next
__________________
Build Log: http://forum.overclock3d.net/showthread.php?t=72241
“If you knew the magnificence of the three, six and nine, you would have a key to the universe.” – Nikola Tesla
  #53
Old 08-03-18, 07:02 PM
Daiyus's Avatar
Daiyus Daiyus is offline
OC3D Crew
Looks great. How are you getting on with them?
I really like that design. Makes my old Thrustmaster Cougar set look plain and dull.
I really need to try voice attack, however the game doesn't play nice with my bluetooth headset. I have to disable the mic to get stereo audio.
__________________
  #54
Old 08-03-18, 07:19 PM
Tolemac's Avatar
OC3D Elite
For £115 i'm impressed tbh but it does need "fine tuning" as does voice attack with the HCS packs
Commander Tolemac reporting in with his ship Lollipop's Revolt o7
Lollipop is my pet dog btw
__________________
  #55
Old 08-03-18, 09:31 PM
jimma47's Avatar
jimma47 jimma47 is offline
OC3D Elite
Nice work. I have the left forefinger four way hat switch set up for vertical/horizontal thrusters, comes in really handy.
Docking computers are great on larger ships but don't 100% rely on them keeping you safe . Sometimes you hit the deck pretty hard. Shame you can't map the computer to a switch or button. You have to manually disable it in the flight control panel if you don't want it to auto-activate. If you're hands on then you hit zero throttle at all as you're just about to touch down the computer can send you back into the landing pattern which is frustrating as you usually hit the lights or tower near the landing pad.
Don't forget that while there's nothing stopping you entering the station upside down or back the font, if you enter the with the Green light on the Right of your ship - Red is left (Port), Right is Green (Starboard) - then the Landing pads are always numbered the same. This helps you locate Docking bay 22 for example as it's always in the same direction. Saves you running out of time looking for your landing pad.
I have voice attack but rarely use it -mainly because the mic is on my headset and I use speakers most of the time.
It would be nice to get one with attitude.
Like when you fall out of supercruise for being too close to the star it gives you some Rogue One K-2SO - "That was bad. That was really bad."
__________________
Rig Gallery - Krusty III
  #56
Old 08-03-18, 11:35 PM
Tolemac's Avatar
OC3D Elite
I have my thrusters set the same I made this small YT video I just couldn't remember the comms channel voice command
__________________
  #57
Old 09-03-18, 08:34 AM
Warchild Warchild is offline
OC3D Elite
As I mentioned. Voice attack gets better every time your run the microsoft speech recognition tool.
It uses that tool to adapt to your view. After 5 run throughs, VA recognises all my words even if I mumble them now.
  #58
Old 09-03-18, 03:13 PM
SuB's Avatar
SuB SuB is offline
The Webmaster
Nice, protip, find a way to lower the throttle and stick from an arms raised position, to an arms by your side or on your lap position (or lower ideally) and it'l help with your shoulders/arms/wrists a LOT in the long term.
There's a reason our ingame cmdr's have them where they are
Lollipops revenge is a good name for a ship , time to earn some credits now eh, 1000 won't last long
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #59
Old 09-03-18, 03:15 PM
Tolemac's Avatar
OC3D Elite
Thanks for the tip Sub i'm sure my woodworking skills will come in handy there
__________________
  #60
Old 09-03-18, 03:17 PM
OC3D Elite
Lucky man, with those skills! I ended up shelling out serious $$$ for MonsterTech HOTAS mounts. $420CDN later, for a sub-$200 HOTAS, just because of lack of skills! But I must say it makes sooooo much difference, and it WILL save your shoulders.
Be sure to make a DIY thread on those when you get at it, that would be awesome to see!
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
