Go Back   OC3D Forums > [OC3D] Customer Care Forums > NZXT Forum
Thread Tools Display Modes
  #1
Old 24-10-17, 09:20 AM
denial denial is offline
Newbie
Exclamation Nzxt x52 with Corsair SP120 fans
Hi all,
i am thinking changing the stock nxzt fans from my X52 kraken with 2 SP120 connected to cpu_fan & opt_fan connectors of the motherboard to complete the rgb scheme which look nice imho .
My question is if the SP120 fans will be sufficient since they are 3pin fans and i will not have the pwm control to cool the radiator and the overall perfomance will not be affected and have issues .
Has anyone did this who can tell me for sure that everything will be ok and i will not have issues?
I know that i can get pwm corsair fans but i cannot afford to change 4 fans i already have, so adding 2 more will be cheaper for me :/
Thanks !!!!
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
